Question about HP Pavilion TX1320US Tablet PC
What makes a computer powers up and not boot,after booting previously?
  • 10,865 Answers
Unplug your laptop and then remove the battery. Replace the battery and start it up. IT should now be reset and work. If it still does not work you have a more serious issue which will require a technician.
Posted on Jul 16, 2009
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
PLEASE HELP my iPad 4 wont re-boot. after the apple emblem it shows a small circle with itunes in it and what looks like a cord you use to charge a iPad if you touch it or try sliding it nothing happe
Seems that your iPad has been reset to factory. You will have to plug it into your computer and launch iTunes. From there you should be able to restore from your previous sync. It helps if you use the computer you originally set up the iPad with.
Jul 03, 2014 | Apple iPad 32 GB WiFi Tablet PC
I cant remember my ipad password and i have tried everything what do i do?
1. Boot iPad into recovery mode (You can find instructions online that explain this specifically)
2. Connect your iPad to your computer and open iTunes
3. Restore your iPad from previous backup
Nov 08, 2013 | Apple iPad (16 GB) WiFi Tablet PC
No internal drive appear during booting
Try changing the SATA / IDE mode in the Bios. Make sure the BIOS is seeing the hard-drive.
May 31, 2013 | Motion Computing M1300 Tablet PC
Tablet wont boot into anything but screen with horizontal lines..just got it today and charged battery and now i get nothing?
Holding the power button down for 10-15 seconds is considered a hard reset on most tablets. If it still won't load you can try doing a factory restore.
  • Make sure the tablet is powered off
  • Briefly tap the power button once, then hold the power button and volume down until you get the boot menu
  • There should be an option to factory reset or something to that affect
Dec 08, 2012 | Tablets & eReaders
During restore windows i found error "Windows could not complete the installation. To install windows this computer, restart the installation.
Reboot windows without any CD in drive and tap F8 key before windows screen appears. Select safe mode from the menu that appears and elect to do a system restore.
If this doesn't work you could try changing the boot order in the bios ensuring that your hard drive is first boot device. should get into bios when starting PC usually F2 or del key. remember to save changes in bios normally F10
Oct 13, 2012 | eMachines E730, Core i3-330M 2.13GHz,...
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Feb 28, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
No icons or taskbar after booting.
Have you tried a safe mode boot (press F8 just before the win start screen and choose safe mode) to see what happens and check for the installed programs. Also try in safe mode with network, update yor antivirus and do a full scan.
Stelios.
Feb 20, 2010 | Fujitsu Siemens Stylistic 3400 Tablet PC
I am trying to Downgrade an ASUS R1F from Vista Pro to XP Pro. How do I get the tablet to boot from the CD
Hi, if you have computer knowledge, the easiest thing to do is to take the laptop sata hard drive out and connect it to your computer with your sata cables and power and boot your computer up and the laptop drive will be a slave drive then. Now you can back it up if you want and then format it.
Now turn your computer off and put the hard drive back in your laptop. Because there in no Operating system the laptop will ask for a boot device. Now you will be able to boot from your xp cd.
I don't know why but I have found most laptops and computers with vista don't like to boot from a cd and over ride the boot options and go directly into vista which makes it hard for people who want to down grade to XP.
Why someone would want Vista beats me.
You can also load up into bios and change your boot options in there. If not already set as first boot device to be you cdrom/dvd you can change it to be. But like I said most of the time with Vista it doesn't matter! Vista will still boot first. But it is worth trying.
Sep 26, 2009 | ASUS R1F Tablet PC
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
HP Pavilion TX1320US Tablet PC Logo
274 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
