Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't drain, the lower plug is clean, displays
Code "F", and then continues to buzz signaling the code.
    President:
  • 1,197 Answers
Usually whirpool duet models come up with the error codes with "F" followed my a number..... can u clarify if its just "F" or has a number next to it... it wud help us provide us better solutions to u.....
Posted on Jul 16, 2009
Whirlpool duet f09 error code
it is an overflow condition caused by either a plugged drain pump or a bad pressure switch,if you hit pause/cancel and the drain pump continues to run then check the drain pump cleanout for foreign objects
Aug 31, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading machine stops before the final spin cycle, leaving loads full of water. Prior to stopping the display shows 18 to 22 minutes left in the cycle, but suddenly stops. There is no...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9100lw2 Duet washer will not drain or spin. was flashing a "F" on the display...
remove the lower panel on the machine and you will see the water pump and right next to the pump you will see a drain plug --- turn the plug counter-clockwise and unscrew it. let it drain,, and clean out any blockage that may be in there. after it is clean,, re-install the plug and start the wash cycle,, this should solve your problem.
if you are still having troubles - please feel free to write me back here,, Ii will do my best to walk you through any steps needed.
c...
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool model # GHW9400PL2 solution for the FO2 error indicator
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have the front loading duet washer. The code F
F2 indicates a long drain usually caused by blockage in the filter, remove and clean out filter.
Also Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
If the above does not correct the problem, replace the pump
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet won t spin continues to beep and
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
318 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
