Question about Car Audio & Video
Subwoofers stop working after few seconds
I was just driving one day and they stopped working. Just replaced same amplifier thinking the amp was the problem. All fuses are good.. Once I turn on the car the subwoofers work for a few seconds then I try turning it up and the subwoofers stop working, they only work for a few seconds... The amp is not in protect mode.
    Problem Solver:
  • 13 Answers
Check the subs wiring... follow the manual....
Posted on Jul 18, 2009
Car amplifier stopped working.
what gauge wire are you using
Apr 24, 2012 | Car Audio & Video
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
A few days ago the subwoofer stopped working. Yesterday I turned the system on and it wouldn't work at all. I discovered the fuse had blown. I replaced the fuse, couldn't find a slow blow fuse so had to...
Try removing the wires to the subwoofer and then hook a "aa" battery to it and see if it makes a pop sound..this will tell you if speker is ok...if it is then I think the amplifier sectionj for the sub is what is blowing the fuses...you are probably right..it looks like it's a 1 A fuse...but if it's blowing right away..it may be circuitry related
Jan 04, 2011 | Altec Lansing VS3251 Speaker
Amp light on , but subwoofers stop working after 5 seconds
check sloder conection in amp. if your amp is in trunk it copuld have over heayed and mealted the metal.
Jul 12, 2009 | Alpine MRP-M500 Car Audio Amplifier
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Amp is shutting off after 10 min of driving!! please help!!
Does it happen at all volume levels?
What is the gain setting on the sub amp?
Have you checked for 12V @ remote turn on after problem occurs?
Sounds as if the remote turn on relay inside the amplifier is losing signal, or has become damaged. If the protection light does not light up, the problem is not thermal, shorting, or high/low voltage.
The amplifier is in need of repair. This is not an end-user fix. Looking at about $50 to repair.
Thanks for using FixYa- a FixYa rating is appreciated!!
Feb 18, 2009 | Profile BAJA HA700M Car Audio Amplifier
Subwoofer acting wierd
If you turn the power off and restart, the most logical answer i know of is your amplifier is going bad.
I am not sure of the model and brand of your amplifier, but there should be a protection light on the amplifier somewhere that will most likely be on, caused by overloading the amplifier.
You will most likely have to replace the amplifier, or check with the manufacturer to find out if they can repair it or help to further diagnose the problem.
Dec 16, 2008 | Car Audio & Video
Subwoofer amplifier
This could cause from different issues.
1. Check if there's any voltage leading from your ignition to the remote cable on the AMP. If you have voltage on the ignition check the fuse that connect inseries on the remote cable.
If the fuse ok you might have other problem in the Audio Output stage.
Good luck.
Dec 13, 2007 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
186 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
