Question about MSI WIND U100 Notebook
Problems with USB port and charging mp3 player with MSI Wind U120
When I plug my mp3 player into my MSI Wind U120's USB port, the player won't charge. (And I've tried all the ports, I've tried when the computer has been on not too long, starting the computer with the device plugged in, etc.). I am prompted to install network hardware, but I really don't need to for this device, and it has charged on the computer before. I think this might be similar to the problem I encountered with my plug-in speakers, which would not work until I restarted the computer (and apparently, something with the computer reset itself; the computer is plug-and-play). The charger works on other computers, so I know it's a problem with the Wind. Unless I install the hardware, which I don't have, the mp3 player isn't even recognized in the ''My Computer'' section.
Thank you.
  • 62 Answers
Do the usb ports work at all, if not open the case and see if there is a loose wire.
Posted on Aug 21, 2009
Won't charge when plugged in to USB
Often the problem is the USB cable or the plug.
Make sure the USB cable is plugged in firmly, all the way on both ends. If it still does not charge, try using a different USB port on the computer or laptop. If that fails to solve the problem then get a new USB cable.
If none of the above solves your problem then your device is defective.
Jan 13, 2013 | SanDisk Sansa Fuse MP3 Player
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
Dec 04, 2011 | MSI Wind U120-020US Netbook
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
I dont how charge battery on my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Audio Players & Recorders
How dont know how to charge my mp3 player
Dec 25, 2010 | Philips GoGear Flash MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
USB Port 2.0
USB Port location
Battery
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Battery
Latest firmware
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
MSI WIND U100 Notebook Logo
640 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
