Question about Panasonic VIERA TH-C50HD18 50 in. Plasma TV
How to connect an audio system to TV
I would like to add speakers to our flat screen TV. I don't know if I can connect 4 speakers to the TV or if I need an amplifier with the speakers. We are using the TV in our club house and the small built in speakers are not adequet.
Thank you,
Tony
  • Anonymous Mar 21, 2014
    I wish to power small but good speakers from the tvs internal amplifier... the concept works well except for the hideous amount of EQ applied for the benefit of the internal speakers - I need to turn off those audio filters.
    President:
  • 2,992 Answers
You really can't add too much since the set's amplifier was designed to work with the internal speakers. What you'd be better off doing is buying a stereo receiver (or a home-theater system) and a couple of sets of speakers. Feed the audio output from the TV (on the rear or side, wherever they are on your set) to one of the receiver's inputs and you're off and running. You'll get more flexibility with a setup like this as well. If you don't want to watch TV you could still use the system for radio or CD playing as well.
Posted on Jul 16, 2009
I have a Sony Bravia KDL52S5100 , I connected my PS3 through HDMI and connected external speakers through the 3mm audio out on the side. It used to work fine but now the audio is not playing through my...
This information comes from the online reference book: Using the Sound Menu
Use the remote to open the TV menu. Select the Sound menu, and the "speakers" decision. From the two choices, "TV Speakers" tells the tv to use its built-in speakers. "Audio System" tells the TV to use an external audio system, and disables the internal speakers. Select "Audio System," and check to see if it works. If it still hasn't recognized that there is an external audio system plugged in, you may need to clean the stereo mini jack (3mm audio jack) with a small wooden toothpick or similar small diameter non-conducting device.
Feb 27, 2014 | Televison & Video
Can i hook pioneer speakers from a system to my lg flat screen
Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
Feb 13, 2013 | Proscan 32LA30Q Television
I want to connect my mp3 player to either my soundbar or flat screen. How would i go about that?
Hi
You don't identify your make and model of MP3 player or your Flat Screen TV.
Some types of MP3 player can dock into a device (MP3 Dock) that has audio output connectors that can connect to either your TV or your Sound Bar with either standard stereo phono or HDMI cables (your TV has HDMI capability).
If no dock is available for your MP3 player, a stereo phono to 1/4 inch stereo jack will connect either audio Out or Headphone Socket to your TV or Soundbar. The sound quality may not be the best with this type of connection but it should be adequate.
A retailer like Radioshack, Best Buy, PC World, Maplin, etc. (depending on where you are) should stock these MP3 Docks and cables.
Hope this helps.
Aug 24, 2011 | Vizio VSB210WS Soundbar
BOUGHT NEW FLAT SCREEN NEED HELP HOOKINF UP DVD/VCR
1. Video Output from DVD .. and Video Input in the TV..Used your Yellow cable for Video Output... 2. Audio Output from DVD and Audio Input in DVD (if your TV have a built-in Speaker)
Red & White Cable for Audio Output..
If your DVD has its on Speaker... don't follow the step 2.
if no sound.. please see to it if your speaker of your dvd is connected.. (if not Please connect it)
Aug 19, 2011 | Televison & Video
My TX-SR500 rear speakers stopped working,I tested each speaker using the channel select to optimize the rear speakers but the left and right front speakers were adjusting instead and I know I have the...
And you don't think the speakers are wired wrong. Re-investigate or reposition the speakers you THINK are Front to the Rear and go on from there.
Jul 31, 2011 | Onkyo TX-SR500 Receiver
LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
May 16, 2010 | LG 32LB9D TV
Can I hook up my Model TR 6030 to my Samsung TV?
I can't find a match for the model. What brand is it?
Generally, any modern all-in-one will interface with any modern TV. It all depends on the connections matching up. Keep in mind that the system is for the audio and source origination while the TV is there to add a visual, not audible, aspect to your enjoyment. If there is something the TV can display it probably originates from somewhere that could connect directly to the audio system, so let the specialized audio equipment handle the audio while the TV handles the video.
The TV probably has HDMI, component and/or composite video connections. Use whatever Video output matches on your all-in-one, in that order of preference and decreasing video quality.
For TV-based listening (that usually means 'cable), use the audio output of the cable box primarily in the following order of preference: HDMI, optical or coaxial digital, analog (RCA). Without brand/model specifics, I can't guess what that would entail.
Jan 31, 2010 | Audio Players & Recorders
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Panasonic VIERA TH-C50HD18 50 in. Plasma TV Logo
492 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
