The only simple thing one can do is too check the fuses for this , actually I think these devices have a circuit breaker ,there the silver things in the fuse panel under dash , if the fuse goes again , ck your window seals 4 cracks as mine went bad and leaked water down into the motor and messed up all the works
SOURCE: 2000 mercury mountaineer power windows won't work
check for a broken wire in the wiring between the body and door
SOURCE: I have a 2000 mercury mountaineer. Power door locks
Fuses would be the first suspect. Look for a small bread-loaf size box that contains all the fuses and relays. If a new fuse pops as soon as a seat or lock is operated, then look for a stuck motor for the seat or a shorted solenoid for a lock that was just operated. If it pops as soon as replaced, then suspect a wiring short.
