Question about Saeco Vienna De Luxe Espresso Machine
Grinder settings for Vienna Deluxe
I do not know how the grinder settings should be set for our Saeco Vienna deluxe..There are two wheel settings at the top of the coffe bean reservoir, how should they be set?
  • 1,089 Answers
Hi
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
Posted on Jul 16, 2009
Two weeks ago I paid > $100 for a full service (Saeco Magic Deluxe) and now the machine won't grind the coffee beans. Any suggestions so I can be a bit "knowledgable" if I need to take it...
Hi
If the grinder is spinning your grind set is too fine. Push the lever below the bean hopper to the back. It can go to a coarser setting anytime but the grinder has to be spinning to make it finer. They may not have set the grinder correctly. Have them walk you through the process. It also takes about 2 to 3 times before the grinder fills to work.
Apr 13, 2011 | Saeco Magic De Luxe Espresso Machine
My magic deluxe is grinding very coarse on number "1" grinder setting and the coffee is very weak; do you think the grinder blades are blunt? the machine is 13 years old.
Hi
Your grinder has seperated. The cork screw in the center is not centered. Grinder needs to be replaced. If you want one let me know.
Jan 21, 2010 | Saeco Magic De Luxe Espresso Machine
Weak espresso.
If you cannot adjust the grind any finer, youmight have to open the grinder and reset burrs or replace them.
Oct 06, 2009 | Saeco Vienna Deluxe
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna Deluxe grinder doesn't work properly
Try to open the steam knob and make a cup of water.
Make sure everything is in place.
One more thing you can try is:
open the door, take out the brewing unit, driptray and dregsbox.
Look in the machine and you will see three hole, one in the lower left corner, one in the middle above the driving shaft and one in the right upper corner.
Turn on the machine and put a screwdriver in each hole and see if the lights go off.
Hope this will help you.
/Mirran
Sep 02, 2008 | Saeco Vienna De Luxe Espresso Machine
Grinder setting i
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
Oct 22, 2007 | Saeco Vienna SuperAutomatica Coffee...
Clogged Saeco Vienna de Luxe
Grinder sound like it is grinding to fine. Increase the grinder size. Remember to only change grinder setting when the grinder is spinning.
Hope this helps!
Sep 11, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
496 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
