Question about Briel Chamonix ES-35 Espresso Machine
Looking for the portafilter blank in order to backflush the system. hubby won't drink the espresso its making. thought i'd clean it but can't find the blank. can you help?
  • 37 Answers
There is no blank made for home Briel machines and I could be mistaken but I thought it is due to you usually do not backflush a home unit because the internal system is different.??
Posted on Jan 14, 2010
    President:
  • 1,618 Answers
It is possible that a regular rubber disc from a commercial machine might fit, check with the nearest espresso machine dealer.
Posted on Jul 19, 2009
Can i backflush my 2002 Steel Uno Pro
You need to check if you have the solenoid valve, if you do, then back flush regularly to avoid group blockages.
You would want to descale regularly as well to avoid the solenoid blocking.
JURA descaling tablets
Sep 23, 2014 | Ascaso Steel uno prof Espresso Machine
Tip
Proper way to backflush a Rancilio Silvia.
Rancilio does not recommend backflushing the Silvia. Sometimes we have to.
First remove the brew head screen. Clean the brew head screen and reinstall. The proper way to back flush is to use a blind basket. Place some Cafiza, or Joe Glow (espresso machine detergent, a level teaspoon) in the blind basket. Insert blind basket in the portafilter and insert the portafilter in the brew head. With the machine warm, turn on the brew switch for about 4 seconds. If the pump starts to get quieter, turn the pump off. Wait about 1 minute, and repeat.
Do this about 5 to 10 times until the 3 way valve runs clean. Rinse the basket and repeat about 5 times to rinse machine. Remove and brew some more through the brew head.
Never let the pump get quite when running the pump, while back flushing. This can damage the pump.
on Jan 01, 2010 | Coffee Makers & Espresso Machines
Gaggia Baby filter is stuck!
The filter is stuck on the group head of the machine only by the force of dry coffee which acts like glou and since on the portafilter is secure by a wire spring which is probably loose and couldent hold the filter in place.
So all you need is a pointing screwdriver with edge like a nail or similar and use it on the filter try to level it out and by a little force try to move it and get unstuck. After that you can clean also the coffee remaining's on group head also.
In order to avoid this in future you will have to clean the portafilter from machine after you will make a coffee, replace the portafilter spring with a new one and clean the grouhead and grouphead gasket often with grouphead brush. You may need also to buy cleaning grouphead powder and backwash blid filter to perform backwash frequent. All these cleaning and parts you can easily find in eBay.
Jun 09, 2013 | Gaggia Baby Espresso Machine
Excessive water comes out the drain when brewing a expresso
Hi
Your 3 way valve is dirty or bad. Have you ever done a back flush with a detergent?
About every 3 months it is a good idea to do a backflush your machine with a blind filter basket. When backflusing you should only use a good espresso machine cleaner designed for an espresso machine's brew system. DO NOT USE a decalcification cleaner. First, clean the screen and dispersion plate plus the brew head and reassemble, which will prepare you for backflusing. Then, insert the blind filter basket into the portafilter with a ½ teaspoon of cleaner in the basket. Next, place the portafilter into the brew head and tighten. When the machine is hot turn on the brew button for about 10 seconds and then turn off. Then, wait 30 seconds to a minute. Next, turn the brew button on again this time for only about 3 to 5 seconds and then turn off. Wait 30 seconds to a minute. Repeat these last two steps six to eight times. After you have completed the backflushing remove your portafilter and rinse the blind basket with fresh water. Next, you turn on the brew switch to rinse the plumbing. Then, reinsert the portafilter into brew head and turn on the brew button for about 10 seconds and then turn off. Next, turn on the brew button for approximately 3 to 5 seconds and then turn off. Repeat about 4 to 5 times. Always remember backflushing is hard on electric 3 way solenoid valves, so it is not recommended do this no more than four times a year for a machine used in home application. You will find more good is done to your machine be properly cleaning the brew head.
Apr 23, 2011 | Pasquini Livia 90 Espresso Machine
I get espresso grinds up on the machine above the filter basket after I make espresso.
Hi
Sorry to say but that is pretty normal. One trick we did is after making the espresso for the day, we emptied the portafilter basket of grounds, then put the portafilter back in the machine and ran the pump. Once we had water coming from the portafilter, we loosened the portafilter back and forth a couple times and this would clean the gasket and brew head. The gasket is very important and a dirty gasket can lead to trouble down the road.
Jan 07, 2011 | Solis Crema SL-90 Espresso Machine
I do not know how to use the Blind Diaphragm filter
The blind filter is used to backflush the group with espresso machine soap to get rid of the coffee oils.
May 30, 2010 | Rancilio Silvia Espresso Machine
No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
Dec 03, 2009 | Saeco VIA Venezia
I have a Briel MultiPro espresso maker. When I try to make coffee, water/coffee starts running over the edge of the basket and it "spurts" coffee and grounds after a few seconds.
The group head gasket needs to be cleaned or replaced. First get a brush and clean put the head, then insert back wash filter(basket with no holes) in portafilter, make sure that it is seated properly(atleast 90° angle with machine), then run the head if nothing leaks around the portafilter the gasket is fine, if it leaks then replace the gasket. Make sure that you press the stop button before removing the back wash filter.
Jun 23, 2009 | Briel MultiPro Espresso Maker - Brushed...
Espresso machine will not make Espresso.
Try this remove the portafilter and press the brew button, if water comes out of head, machine is fine but the grind or the tamping(packing pressue) used on the coffee is not right. If you are grinding the coffee just before using it, try a coarser setting. If you pre grind at the store then try tamping the coffee lighter.
May 29, 2009 | DeLonghi BAR 14 Espresso Machine
I was backflushing my machine and now the portafilter is stuck
The brew solenoid is not discharging the pressure from the group, the line might be clogged, if you remove the top and then side panels of machine you will see the discharge tube flowing into the drain tray, try unclogging hole, then backflushing to see if the solenoid discharges.
May 13, 2009 | Pasquini Livia 90 Espresso Machine
Briel Chamonix ES-35 Espresso Machine Logo
159 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
