Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Kenmore side by side refrigerator ice maker
Our refrigerator was leaking water from the rear left. Company came out, told me it was the water to the ice maker and water in front of the unit. Replaced something, and checked that the water was working. I can get water from the front of my refrigerator, and it no longer leaks; however the ice maker isn't making any ice. Freezer works just fine.
SOURCE: Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Posted on Aug 14, 2007
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck
Posted on Apr 30, 2008
  • 172 Answers
SOURCE: kenmore coldspot - How do you remove the ice maker box to clean
Hi Cincygrl,
Well lets see, I believe you have a whirlpool made kenmore, Your model numer should start with 106.
The problem you are having is from our drain. When you freezer defrosts the water should drain down a tube and under the refrigerator into a pan. If the tube gets clogged it will leak water into the freshfood section. To clear the drain you will need to remove everything from the freezer and remove the inside back panel in the freezer. in the center bottom under the coils and the heater you will see a tiny hole. That is your drain. If it is frozen over you will need to defrost the ice or you may need to run a smaller tube into it to clear it of an obstruction. I use a small rubber hose and I just insert it into the hole and blow on the other end. If you have something in it, it should blow out. If it does not then it may have ice in it and you can pour hot water into the drain and defrost it. Once clear you should not have any further problems. But they do make a drain heater probe to keep ice from forming inside the drain. You can get one for about $6.00. Good luck and I hope this helped you.
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker,
Posted on Jun 23, 2009
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
0 characters
1 Points
Water is leaking from the Ice maker on top of the
the water valve on the back of the fridge has malfunctioned.
Jul 21, 2010 | Kenmore 57029 Side by Side Refrigerator
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Nov 25, 2009 | Kenmore Refrigerators
Kenmore Side by Side not making ice
This problem is most likely the water control valve on rear of refrigerator. If your ice maker is empty pour tap water inside it and let it freeze. If it dumps the ice then the water control valve. If nothing happens the the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Mod: 10651262103, icemaker leaking, not making ice
We need to know if the ice maker overflowed or if there is a crack. Sometimes the water gets frozen in the fill tube and diverts the water everywhere other that ice maker. Rare but sometimes something causes the water control valve to stick open on rear of refrigerator. Your ice maker has a thermostat inside it and starts a cycle when the thermostat says the water has frozen. That starts a cycle of about six thing to happen.The defrost element below ice maker warms the bottom just enough to loosen the ice. Micro switches feel and sense the position and as it nears ending the final step the ice maker tells the water control valve to open for a few seconds. An adjustment in that control may stop over flow. But if cracked in a major section it will need to be replaced. Let me know if this helps you. Sea Breeze
Jun 20, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water inlet ot ice maker leaks in to frezzer
Change the Water enter dump valve for the ice maker. It is leaking. It will not shut off & will cause this problem. It`s infrequently located in the rear of refrigerator ussualy where water line enters the electrically back of refrigerator. In essence the valve and electric head can be bought at any Appliance Parts store. It`s not a high cost part and be bought easily for it is mostly a standard part to buy. erroneously bring the model number and serial number and they can get the right one to replace it with.
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker
water valve on back of refrigerator
the water line connects to it
it is leaking a tiny amount of water and it freezes
in the inlet tube to the icemaker.
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
