Question about Welding Tools
Hello i just bought today a dremel versatip and it broken already
i loded it with feul it worked for like 1 hour
then it stopped igninthing it seems that gas is escaping some somewhere around the ignithing button
and one more thing
once i realese the button gas is still escaping and i havent locked it
is there anything i can do here at home
SOURCE: 22' Gateway FPD2275W LCD monitor menu locked
Here is the solution, it worked for me!
http://support.gateway.com/s/MONITOR/7005483/7005719Rfaq104.shtml
Posted on Mar 07, 2008
SOURCE: Can't turn gas **** past pilot
Unfortunately, Mr. Heater does a very poor job of writing user manuals, I didn’t even know my unit had a quick connect until I saw it on the side of the box. As it turns out, the spring loaded fuel **** has three positions; full up for safety lock, fully depressed to select/ignite the pilot, and half depressed to select the heat levels. I guess it was just dumb luck that I managed to get it to work the first time since there is nothing in the manual about this. Since I discovered the third position (sheerly by accident) I have not had any more problems.
Posted on Dec 26, 2008
SOURCE: overlocker machine janome harmony 9102d
try taking the foot and the plate off and try threading it then get it going without the foot on and see what happens just got mine going
Posted on Feb 17, 2009
SOURCE: New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Posted on Jun 14, 2009
  • 176 Answers
SOURCE: Feul pump stopped working. I changed the relay, it
Did you install a new pump? Used pumps may be cheaper but not if you have to change them.
Posted on Jul 09, 2009
Although I had only used my Dremel versatip once I am told it may not be holding the solder due to oxidization, how can I clean the tip of the iron
Clean it with some fine sandpaper and then dip it in flux. Then apply some solder to the tip again and it should b good to go.
Jan 25, 2015 | Dremel Versatip Multi-Purpose Tool Kit
The pot metal in front of thequick release tension lever has broken and fell out. can I still use the saw If not where do I go to get another one 1830 120v 18inch scroll saw dremel
I believe the part you are looking for is called a "locking rod" dremel part number 2610922661, this is the black painted pot metal that is about 3" long attached to the upper arm rocker with a parallel pin, and the flip clamp (blade tensioning assembly) or it could be the small piece attached to the tension assembly that the blade attaches to which is silver and called the "blade holder assembly-top" part number 2610922683. I would recommend ordering both directly from Dremel CS 1-800-437-3635. I broke the locking rod on mine. I emailed dremel, and they emailed me back the next morning with a schematic, and parts list. I bought 2 and paid $10.41 total.
Mar 08, 2011 | Dremel 1830 120V 18" Scroll Saw
My Dremel Versatip wont melt the solder - it gets hot, as I touched it to a piece of paper and it burned through, but why wont the solder melt?
Christina, It's probably dirty, and dirt is lousy for transferring the heat from the tip to the solder. With the iron hot, wipe it on a wet rag. This should immediately remove the black crud and make the tip shiny. Keep a wet rag handy to do this often if you are soldering for more than a couple of minutes. If the crud is too bad, you can use a bit of soldering flux on the tip, then the wet rag. If that doesn't work, you can file the tip (easiest when it's cool) until you have copper showing all around the tip. Please vote if you found this helpful. Good luck, Al K
Feb 16, 2011 | Welding Tools
I just bought it 2 days ago and when i go to plug it in, it wont heat up. it was working fine this morning (10 hours ago)
If you just bought this two days ago it is still warrantied and would not be worth fixing it because you would void the warranty on it I would suggest bringing it back to where you bought it if you have any further questions message me back or if this is not warrantied message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks again Rick
Jan 25, 2011 | Dremel 1550:30 Versatip Tool Kit
I can't find instructions for dremel versatip to change the heads how do you do this
The pdf manual is here: http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00554v-1.pdf
BUT it doesn't explain how to change the bits. If I remember correctly there is a grub screw near the tip that you loosen with a small flat blade screwdriver to change the tips. If your model is different then perhaps posting a picture would make it easier to give a better description.
Apr 05, 2010 | Dremel 1550:30 Versatip Tool Kit
Plastic gears broken on dremel 395
Hello. Call Dremel technicians directly for both parts and service. If you want to repair it your self let them know and they will ship you the parts you require
Phone:
1-800-437-3635
toll free:
1-262-554-1390
(7am-6pm CT Mon-Fri)
Mar 23, 2010 | Dremel 395 Variable Speed Multipro Rotary...
CEL on emmissions leak. I want to try to chekc all hoses for leak
the only efective way to find an evap leak is to use an evap leak tester(smoke machine) you clamp off the the vent hose and hook into the service port and look for the smoke. thats really the only way to pin point it unless somethings oviously broken but it could be anything in your fuel system .
Mar 15, 2009 | 1996 Volvo 850
Versatip 2000 gas soldering iron wont turn on.
Make sure the wires inside the wall plug are all secure, aswell as the ones going to the element inside the iron. If everything looks okay it might be the thermostat, which senses when the iron is too hot, and switches it off and on keeping the heat regulated. This component is replaceable, but you'll need to get one from the dealers. Hope that helps.
Feb 21, 2009 | Dremel 1550:30 Versatip Tool Kit
Welding Tools Logo
158 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
