Question about Speed Queen AGS28AWF Gas Dryer
Ne5513w How do i access the drum - Speed Queen AGS28AWF Gas Dryer
  • 547 Answers
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Posted on Jul 18, 2009
My samsung front load drum is really hard to spin bc something is rubbing inside against the drum..Clothes or debris. How do I access the drum via a baffle to clean out?
John, you are most likely going to have to take the whole machine apart to access the drum and the front cover.
God bless your efforts.
Nov 07, 2016 | Samsung Washing Machines
Drum stopped turning mid cycle, think something is stuck, have opened up backbut cant access drum
If there is no removeable cover on washer, then you have to remove therear half of the cabinet to gain access to the drum etc.
Jan 17, 2010 | Zanussi ZWF1430W Front Load Washer
One of dryers 3 crossbars in side the drum is loose. Is it bolted from outside the drum, and if so, how can I access the out side of the drum to tighten' Jordan Richin
some models you can access drum from the front and some from the top without a model# hard to say for sure but very easy
Oct 01, 2009 | Dryers
How do I find the heating element in a speedqueen dryer model NE5513W
The element is in the left rear as you face the front of the dryer.
Remove the front panel to gain access to the element. Make sure power is disconnected before servicing dryer.
Below is a link to the element part replacement page, courtesy of www.repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-NE5513W-%3d%3di1914&PartID=1914
Sep 20, 2009 | Dryers
Baffle is loose on drum. How do we get access to fix the baffle
The screws that hold the drum baffles in place are located along the outside of the drum. Usually, you need to lift the dryer top in order to access them, and they can be tightened without removing any components. However, all dryers are not contructed the same and access to the drum can vary. If you would please post a brand name and model number it would help in being able to determine exactly how your dryer is configured.
Aug 31, 2009 | Dryers
BRA UNDERWIRE STUCK IN DRUM
not posative but there should be a panel at the back that should come off to get at the drum
Aug 27, 2009 | Candy CN146 Front Load Washer
Drum not turning. Where is belt? Kenmore 110
The belt is on the outside of the drum and is accessible from the rear of the dryer. If you remove the access panel on the bottom rear of the dryer, you will see the motor, where the belt is on the motor sheave (pulley). On some Sears Kenmore models you need to remove the top cover of the dryer to access the belt around the drum (towards the rear).
Aug 02, 2009 | Dryers
Access the drum to replace felt
To access the drum two screws need to be removed from the inside of the door. The screws are on top of the opening and hold the top of the dryer closed. Then you simply lift the top and slide it to the left to remove it, thus revealing full access to the top of the drum. Then two screws (left and right) need to be removed in order to remove the entire front of the dryer. Once the front is removed the drum can also be removed but for the purpose of replacing the felt removal of the drum is not neccessary. It should be noted that the felt sits only around the bottom of the drum and covers just over half of the circumferance of the drum. The felt should be position in around the opening of the inside part of the door. When replacing the front cover the drum will fit snuggly up against the felt. Replace screws, top and door screws and walla...fixed!
May 11, 2009 | Dryers
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
Speed Queen AGS28AWF Gas Dryer Logo
144 people viewed this question
Top Speed Queen Dryers Experts
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
