Question about Memorex MLT3221 32 in. LCD TV
My 32 inch Memorex LCD TV is having color issues -- the best way I can describe it is there is no red. Things taht should be red are brown/bronze. This didn't happen gradually -- the picture was fine when TV turned off, then was bad when TV turned on 3 or 4 hours later. I have tried a reset -- nothing.
  • lpulver Jul 16, 2009
    Thanks for your help -- I'll let you know the outcome.
  • 3,037 Answers
Sounds like either an IC needs to be replaced of the video processor. Either way, this problem will have to be tracked down and the parts tested and replaced and since this isn't a very common problem, I recommend having a qualified shop do it or if the tv is still in warranty, then send it back to the manufacturer or return it to the store and get a different one. No easy fix, I'm afraid. Let me know how this turns out.
Benjamin
Posted on Jul 16, 2009
WHHERE TO BUY A SCREEN FOR 32 INCH MEMOREX TV
The LCD panel is the major cost in a TV, you will be better off just getting a new TV. To et a panel for your unit you will need to contact memorex but with shipping it will almost be the price o a new unit.
May 16, 2012 | Memorex Televison & Video
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
I beleive that the red color is not working most of screen is brown
I don't think it's a red color issue - the LCD or the color processor board is bad. If you know how, re-seat the circuit boards inside the unit and check the ribbon cable that connects to the LCD display.
Dec 29, 2010 | Insignia IS-LCDTV32 32 in. Television
On/off botton
Hi
With the back off your tv, Look at the power supply and check for bad capacitors, this is usually the case with the sympton you have described.
The bad capacitors will be domed shaped or bulged on top and may leak a brown like liquid substance.
Possibly valued at 1000uf / 10v
Remove and replace any you suspect and if capacitor related this will solve your issue.
Hope this helps
Apr 05, 2010 | LG 32LG30 32 in. LCD HDTV
I now have what I can describe as a sepia screen - green background but people don't look green
one of the color guns has failed there are 3 RED BLUE GREEN So red and blue make brown theres how it becomes sepia in color
Aug 10, 2009 | Toshiba 32A33 32" TV
Memorex 32' lcd tv shut off
Hi!
It sounds like you have a power supply problem! You will probably find some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). As far as the noise problem this could be caused by harmonics, from the bad caps!
Feb 19, 2009 | Memorex MLT3221 32 in. LCD TV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Looking for wall mount for MLTD2622 26" tv
I had similiar issue with 32 inch...bracket required an adapter which I found through Best Buy. Check out Sanus.com They should give you discription of what you need and tell you where to get it. Adapter was very cheap ($19.00 or so). It is essentially two metal bars that bolt to regular wall mount, the bars will line up with bolt holes on TV.
Dec 13, 2008 | Memorex MLTD2622 26 in. LCD TV
Bravia Color
why can't you adjust the color? What do you mean
Dec 22, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Memorex MLT3221 32 in. LCD TV Logo
37 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
