Question about Polaroid Televison & Video
I have a lcd 37" polaroid tv / dvd combo I use to have it hooked up to Direct TV and now wanted to just get the free channels with an antenna. Eveytime I scan for channels it doesn't find any. Do u think Direct TV changed a setting on the TV to receive their channels?
  • 441 Answers
Go into the set up menu and set the signal input to AIR, the rescan for channels. Directv should have been going into a sat box then into a different input than the Ant jack so make sure your on the right input
Posted on Jul 16, 2009
How do I get channels
ok,if you have a subscription to cable,you will have a cable box,you will only need to put your tv on cable and ch 3 or 4 on your tv,you dont need to search for channels,if you dont have a subscription,then you are trying to pick up over the air channels,they are called digital channels,you will need a digital tv antenna and your hdtv,you will change the settings on your tv to air or antenna,then you can search for digital channels,there are no more analog channels like we had when we are kids,they are all digital and dont need to be tuned in,if you still cant get channels please have someone help you.
May 19, 2015 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Hook up to digital TV antenna indoor passive
Please check if the antennae is connected with right cable and the dipole is good. If so search the channels avaiilable and if there is no signal then it is possible that the TUNER is faulty. check using another TV with the same antennae or check the RF input using a VCR or TUNER.
Oct 30, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Ok i need to know how to hook up a dvd player to the tv. I need to know now. Thank you nina
Is there a cable antenna connection on the back?
If so, hook the DVD cable out to the TV cable in.
Put the TV on channel 3 or 4.
There may also be RCA jacks so you can hook the audio and video up direct.
Jul 15, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I need a power cord for a polaroid HD TV 81.5 INCH
Try using the power cord from your PC. NEMA5-15P to IEC C13.
Jul 12, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
Can't record tv shows
Output of combo to input of TV, and you need the cable / antenna attached to the combo to record what you want to see.
Jan 11, 2010 | Philips DVDR3545V/37
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
I have a polaroid hdtv model TLA-d1911c that wont get a local channel.I bought a new antenna and hooked it up but it still wont pick anything up.
You may be looking in the wrong place or have the wrong kind of antenna. With the digital conversion, TV channels shifted from the numbers they used before. In my area, the previous Channel 6 is now broadcasting in the UHF band.
It can be harder to adjust the antenna for a digital TV because it is either working well or totally off - no gradually decreasing "snow" as a clue.
It is possible your TV is not equipped to pick up digital TV. There are converters to translate digital TV to analog signals for older TV. They cost between $30 and $70 depending on features.
Oct 06, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
194 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
