Question about Kitchen Appliances - Others
I have a Marathon Electric 1-1/2hp pool pump motor with a bad front bearing. Is the motor repairable and if so how do I get it apart?
  • 3,600 Answers
First go to a motor repair shop or Neely Bearing shop and see if they can get a replacement battery, then post a picture of the motor and I will tell you how to repair or replace the bearing. I need to know the frame type, it's located on the motor tag and is it 110 or 220?
Posted on Jul 16, 2009
Bearings for electric motor
replacing bearings can be tricky, but if you are willing to try most of these motors use 6203 2rs c3 bearings all for the back bearing, the front could be 3 different sizes. after removing them bring the rotor to your local pool pump motor repair shop, and have them remove and replace. about $20.
Jul 15, 2015 | Hayward 2HP Pool Pump Motor A O Smith...
Motor red error light comes on, pump won't turn on
if power to motor bad pump motor if no voltage to motor bad relay
Mar 01, 2015 | Marathon Electric Marathon imPower...
Marathon electric motor thermal overload shut down
if it has 2 caps, yes the cap in the back of the motor (black plastic) is for starting motor, and if it has a metal one on the top, this is the run cap, if the run cap is bad it will trip the thermal after a few moments. but make sure you have the voltage set for your application.
Feb 06, 2014 | Marathon Electric 1 H.P. Round Flange...
The motor is making a whirring noise after starting.
If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system. 2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
Jan 23, 2014 | Marathon Electric Marathon imPower...
Is marathon electric 15 hp, 11.2 kw motor equipped with motor space heater?
are you referring to heater to prevent condensation in the motor ? it should have a watt reading on the name plate to state that it does..say 50w or 75w or more . the motor should state, that it does have a heater, use the motor ID and search the web for specs.. so my answer is.... it might ... hope this helps .. jay the pool pump motor repair guy in longwood Florida .... leave a review or a thumb for your fav fixit guy
Nov 30, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Kitchen Appliances - Others Logo
417 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
