G
GRAHAM G T DAVIES Posted on Mar 16, 2016
My telephone is a BT6500 .How do i change my pin so that i can block unwanted numbers. I have tried ringing your help line however there is no reply!
3answers
How block phone numbers that I do not want?
I would recommend an app called LEO Privacy. It can help you add the disgusting phone numbers to blacklist to stop spam and harrassing phone calls from bad guys. LEO Privacy Applock Boost Hide Android Apps on Google Play
4answers
Where do you connect a External Paging Port on Nortel Key Telephone System NT5B05?
this is the link to help you.
http://www.britishtelephones.com/qfmenu.htm
this will help you for sure.
but a service technical at your place will be more better choice.
because if you make one wrong connection some of the function would not work properly.
rate the solution as fixya if it helps you in solving your problem.
2answers
How to block even the first ring from any unwanted call?
If you have a smartphone, an app like mr. number will allow you to block someone from calling at all.
How can I change no. of ringing tone in my BT6500 cordless telephone from existing 3 times to 8 times.
Pages 56 to 58 of your manual should give you the answer if you don't have the manual its available as a download here https://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
Hope this helps
Re phone BT6500, how does one increase the number of rings before it goes to answerphone?
Hi
I give below the step by step procedure for changing the number of rings the phone will sound.
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press until Settings is displayed, press Select.
3. Press to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use or to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Be aware though that the number of rings needs to be less than your ansaphone service, for BT 1571 this is 5 rings, although more may be possible if you can get BT to change their 1571 for your line.
For more information about your phone you can download a pdf format manual from here:
https://www.shop.bt.com/content/uni2/documentation/8h3j/bt6500_user_guide.pdf
This can be saved to hard disk for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
3answers
How do I block calls on my wildcard phone?
Until now, it has been difficult, if not impossible, to block selected phone numbers from ringing your phone. Various features that are offered by some telephone service providers have provided limited relief, at a cost, but until the introduction of the Caller ID Manager, a total solution was not available.
With the Caller ID Manager, you can easily block phone numbers and anonymous callers without added monthly fees. You can now block phone calls from any number that you choose, including local, long distance, international and cell phone callers. A 'Wildcard' feature is included for those who wish to block calls from entire area codes, prefixes, or number sets. You also have the option to block phone calls during specified hours, either on a one-time or daily basis, using the built-in scheduler.
Shared telephone ling malfunctions sometimes
It looks like you have a distinctive ring service from your phone company. Change the ring pattern of your fax to its assigned ring pattern (double or triple ring). It could be assigned to 'all rings' right now, that's why your fax is picking up your landline calls as well.
5helpful
4answers
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
k24674
ADMIN Andrew
ADMIN Andrew
