You just have to unlock the switch kyocera lock it for shipping purpose.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Hi.
C3100: ISU home position error
It usually means the scan carriage can't move.
If it s a little MFP, you can unlock the scan with the yellow button on the left of the glass (under the DP). (This was only meant for transport reason).
Otherwise - Possible cause:
Defective FFC between CCD PWB (YC1) and control PWB (YC8).
- Replace the image scanner unit (ISU)
Defective FFC between control PWB (YC6) and scanner PWB (YC103), or improper FFC insertion:
- Reinsert the FFC. Also check for continuity within the FFC.
If none, remedy or replace the FFC.
Defective home position sensor.
- Replace the home position sensor.
Defective harness between ISU motor and scanner PWB (YC104),
or improper connector insertion.
- Reinsert the connector. Also check for continuity within the connector harness. If none, remedy or replace the harness.
Defective ISU motor.
-Replace the ISU motor.
Scanner carriage error
The home position is not correct when the power is turned on, at the end of a reading process of the table and document processor.
