Building Materials Logo
A
Anonymous Posted on Mar 16, 2016
After connected to the power, the courtesy light flashed 2 times and the up and down button on then off. I pressed up, down and programme button, no respond. What should I do?
jhnolson
Level 3:
  • Master 822 Answers
  • Posted on Mar 16, 2016
jhnolson
Master
Level 3:
Answers
822
Questions
Helped
293008
Points
5434
It is likely that your unit is equipped with a remote control lock out. When the lock is enabled the remote will not work protecting the home.
The Lock Button on the Door Control
The lock button on the door control may be activated. Press the button to turn this feature off. The light bulb will blink two times. This feature is designed to prompt you that the lock button is activated. When the lock button is ON the garage door opener will work from the door control but the remote controls are locked out.
Testimonial: "The door opener does not has the lock control. when the opener connected to power, the motor is not activated, any suggestion? Thank you"
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Wml520 programme panel is flashing
Remove power for some time, open the panel and check the connectors and contacts. When the power is switched on , press down the start/stop button.If the fault does not clear the suspect can be the controller board.
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
1helpful
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
All the best Pineworks
Cannon pixma ip1700 not printing
1. Turn off printer
2helpful
On Canon S9000 A3 inkjet printer error light flashing to indicate 'waste ink tank nearly full'. Can I fix this myself?
1. Turn off power.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
8. Your printer should respond as normal..
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
