Question about HP Officejet 5610 All-In-One InkJet Printer
Squeaking noise when printing - HP Officejet 5610 All-In-One InkJet Printer
    Problem Solver:
  • 15 Answers
How old is your printer? They all tend to get noisier as they get older, could also just need the rail that the print head moves on cleaned.
Posted on Jul 16, 2009
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab5
Posted on Jul 17, 2009
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Canon Imageclass D661 printer is making a squeeky noise when printing. Sounds like whatever is turning is squeaking. Any suggestions?
How old or how much use does this machine get? The older/more use it gets, the more likely it is to start making random noises and squeaks. It could be a lose belt or just need some lubrication, but it's hard telling where exactly it would need the maintenance. As long as it's printing and copying fine, I wouldn't worry too much about it since it doesn't sound detrimental.
Hope this helps!
Aug 25, 2011 | Canon imageCLASS D661 Digital Printer
My P2055DN is making a squeaking noise while printing. Not that big of a deal I guess just annoying. I hope nothing major is on the horizon. Please advise if I should worry about this or not. It...
If you are printing invoices from the MP tray the pickup roller might be squeaking against the separation pad (common with this design). Other common squeak is toner cartridge noise.
Jun 21, 2011 | HP P2055DN LaserJet Monochrome Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Printer squeaks when printing
remove the fuser wiper if the noise is still present remove the fuser and turn by hand. fuser bearings will cause this
Aug 28, 2009 | Lexmark T632 Laser Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Probably, but you?re going to have to try to isolate the problem a little better. Typically this would involve removing side panels and such; however, you may just have a faulty consumable like a toner cartridge, fuser or more likely the transfer kit. I typically try to isolate the sounds location then try replacing some of the consumables in that area one by one. In your case if you can?t isolate the location I would start with the transfer kit since that has a greater chance of making noise. Let us know what you find out and please don?t forget to rate the posting when we?re done.
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
HP Officejet 5610 All-In-One InkJet Printer Logo
424 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
