Question about LG Studioworks 563N 15" CRT Monitor
Problem with Studioworks 563 monitor
I am having problem that the 'pincushion' does not work for adjusting the screen. The screen looks like curved inside both the widths. Please submit the solution
Punit Singh
  • Anonymous May 18, 2008
    horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Posted on Jun 14, 2008
Monitor button & adjust the screen
Posted on Jul 14, 2008
Posted by Biju on 10.05.2008
I am having problem that the 'VIEW' (Transistor) heating hardly very soon and the display going off. Please submit the solution.
Biju Bhattacharya
Posted on May 10, 2008
LG Studioworks 700S 17" CRT Monitor, on screen
Dear Sir,
This problem is not from monitor side,check computer RAM.Clean it twice and reinstall it on place.If you are using VGA card then disconnect it from PCI slots and connect VGA cable to on board VGA . I think it solves your problem.Let me know
Jan 08, 2011 | LG Studioworks 700S 17" CRT Monitor
Resolution problem
This monitor's standard resolution is 1280x1024. I would update your graphics driver. Just go into System Properties, and open up the Device Manager. (Press WinKey+Pause/Break key to open System Properties, and Device Manager is in the Hardware tab.) Locate the graphics driver in the Device list, right click and update the driver.
Feb 26, 2010 | LG Studioworks 700S 17" CRT Monitor
Monitor resolution
Sounds like either the trapazoidal is off or the pincushion is set improperly. You should be able to find those settings via the monitors onboard menu. Either one can create such a problem.
You might also check into finding the factory defaults selection. This will reset all of the resolutions and refresh rate settings.
When you adjust your screen follow these steps in order...
Pincushion : Makes the screen look like ( ) or ) (
Trapazoidal : Makes the screen look like / \ or \ /
Horizontal : Basically stretches the screen wider or skinnier to fit the monitor
Vertical : Basically the same as Horizontal, only with the up and down properties
Contrast / Brightness : Use this to find the perfect white and blacks
Color : Finish your setup with adjusting to the perfect color.
This way you can always have your monitor set like you want it.
Sep 12, 2008 | Gateway FPD2275W LCD Monitor
Horizontal and vertical adjustments
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
Mar 10, 2008 | LG Studioworks 45 14" CRT Monitor
Is there an adjustment for pincushion?
Oct 25, 2007 | Televison & Video
Wide Screen Problem (Pincushion)
Some countries get themselves 'burned' to a spot because of lack of use. a slight twich one way or another will reset it . The control that you are referring to is it a direct acting one - that is does the work or is it of the switch variety- that is you activate the control but then have to move larger wheel to do the work?
May 28, 2007 | Samsung SyncMaster 793DF (Silver, Black)...
Can't Fix Pincushion
If the menu is appearing then it should be able to adjust the Monitor, provided you have replaced the micro switches. Check for continuity by pressing the buttons. I don't think that there is any prolem with other components.
May 05, 2007 | Samsung SyncMaster 793DF (Silver, Black)...
Objects on screen out of window
CRT monitors suffer from the so-called pincushion effect. It is the curving of the actual video picture usually inwards on the sides. There is often an adjustment to compensate for this and it's usually situated near the other user controls. Look for it in you manual.
Now, because of magnetism differences in the world. The monitor is setup to work where it was built. The pincushion effect get worse over time. The degree of severity depends on the location of the monitor and the quality of the design of it to facilitate enough future re-adjustment by turning the pincushion knob.
Apr 17, 2007 | IBM G74 17 in.CRT Conventional Monitor
LG Studioworks 563N 15" CRT Monitor Logo
333 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
