Question about Toys
Play doh dries out. what do you do to keep it or re- moisture it?
    Problem Solver:
  • 18 Answers
I find it stores best in cling film dont know about re moiture it but you can make your own by mixing flour, water and food colouring just add flour until desired consistancy is achieved
Posted on Jul 16, 2009
Samsung s4 has been dropped in water all dried and seems fine but it thinks its in headset mode
Could be there is still moisture inside the headset socket .insert headphone jack into it and the keep drying the input end to see if this cures it.really need to dry this phone out over a week with the battery out as condensation from body heat will keep occurring if any moisture remains.
Jan 19, 2015 | Samsung Cell Phones
How do i remove moisture from my headlights?
First, you should locate and seal the crack with silicone or equivalent. Next, you should remove the lens from the vehicle (if possible) and all the bulbs, connectors, etc. Then get the lens in a warm, dry place to air out, direct sun light works, but be careful not to warp lens. Once it has dried out and all moisture has left, double check that all seams and cracks are sealed, then reinstall lens. Make sure all bulbs, connectors, etc are secure and tight to prevent moisture from returning. Lastly, enjoy moisture free lenses!
Oct 29, 2014 | Vehicle Parts & Accessories
Play doh candy cyclone jammed
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Jan 29, 2013 | Hasbro Play-Doh Sweet Shoppe Candy Cyclone...
If the Play Doh has been left out and become dry, how can I rehydrate it? Can I seal it in its container with a moist piece of cloth, or add some type of oil?
try the official play doh site
http://www.hasbro.com/playdoh/
Even if the tip does work for you ... check out the site anyway they have tons of out to make items with playdoh
This is the tip they give you to re hydrate your playdoh
My PLAY-DOH compound is drying out. How can PLAY-DOH compound be softened or moistened?
To restore the softness to PLAY-DOH compound, try adding water one drop at a time and working it in to moisten the PLAY-DOH compound.
You can also try wrapping the PLAY-DOH compound in a damp paper towel, returning it to the container and replacing the cover. Let it sit overnight
Good Luck. RJ
May 09, 2011 | Play Doh Toys
My amana refrigertor rolls foward when you open the door does it have a wheel lock just purchased model sad2522wrb06 serial #s04326068 email...
Sounds like a very clean kitchen! I would almost like to eat off the floor!
Most refridgerators don't have a wheel lock. Ours didn't. I took a small chunk of play doh and made a small wedge in front of the front wheel.
When we pull it out for cleaning, I pull the hardened play doh off and replace it when I wheel it back in place.
Hope this helps,
Mark
Apr 01, 2011 | Refrigerators
My granddaughter got Play Doh in the carpet. It looked like it was mashed in the carpet. How do I get it out without ruining the beige carpet????? souder.m@sbcglobal.net
Just leave it alone and allow it to dry. When it dries out, it becomes hard you can break it up into small pieces using a stiff brush. Then you should be able to vacuum it up the dried out pieces. Hope this helps you.
Mar 09, 2011 | Play Doh Toys
HOw do you soften partially hardened crayola play doh'
Can't. once it dries out, it's game over. there is a very easy recipe to make your own on family fun magazine's website. Making it is a fun project to share with your young cook/scientist/artist. farmerbear at FixYa.com
Oct 06, 2010 | Play Doh PLAY-DOH Barnyard Pals
My mp3 player wont turn on
I have an identical problem with my mp3 player which looks similar but isn't the same model. There's something up with the play button, some moisture or grit or dust has got underneath the contact for the play button so that the mp3 player thinks you are constantly pressing the on/play button.
Put it in a warm dry place. I have had this problem twice & this has fixed the problem on both occassions. If there's more than moisture trapped inside, that can be harder to shift. But there are no moving parts in this player so don't be afraid to give it a good shake to try & get things moving.
Jan 07, 2008 | Coby MPC-848 MP3 Player
Sansui TV/VCR 13" color
there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
Aug 03, 2007 | Sansui COM311AD 13 in. Combo
Toys Logo
88 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
