Question about Ricoh Aficio CL5000 Laser Printer
It says on machine reset waste toner . How do I do that?
    President:
  • 3,278 Answers
To replace waste toner 1 or 2:
Open the front cover slowly with both hands.
Take out new toner from the bag.
Remove the waste toner slowly from its position by pinching the lever and pulling the handle. Be certain to hold the toner in a level position. Insert the new one in the same position.
Now, to reset waste toner (if toner 1 or 2 is out of position), just remove and reinsert toner.
Hope this helps.
Posted on Jul 16, 2009
5 Suggested Answers
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
  • 624 Answers
This is a duplicate post, click this link to view the active posting: http://www.fixya.com/support/t134401-ricoh_cl3000_laser_replace_waste_toner
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
tbirdfan1
  • 3051 Answers
SOURCE: how can you reset the waste toner counter?
Hello there :
in the main menue of the printer there is a option that lets you reset it to zero but if this is a buisness printer you might have to have the company come and set it for you cause theire somtimes is a code that is entered to get to the main menue
Posted on Oct 23, 2009
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
Our toshiba e5520c colour machine shows an error code cd81. What can i do to solve the problem? Must i reset the machine? Can anybody help please? Thanks Yolande
CD81 is an error code for full waste toner bag, or waste toner auger is being locked up, all you have do is separate the finisher from the copier(a green lever inside the finisher door or hole punch unit door), open the side door on the left side, pull the the waste toner bag out, dispose the waste toner properly, then tap the waste toner bag lightly (to make sure you clear the light sensing area is clear for waste toner full detection), reverse the procedures -please consult your user guide. Better yet, ask your dealer give you a spare waste toner bag.
Jan 30, 2013 | Toshiba T-FC55C Toner for BR E-Studio...
CanonimagerunnerE000019-0000
It seem that something is wrong with the fixing unit temperature. For reset procedure:
E000 on Canon
Dec 19, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
Waste toner tank
Here are the steps to replace the waste toner tank:
1. Turn the machine off, and then wait a few minutes for the machine to cool.
2. Open the front cover.
3. Pull the waste toner container out of the machine using its handle.
Note: Make sure that you lay the waste toner container on a flat surface so that the toner does not spill.
4. Remove the container's cap from the container as shown below, and use it to close the waste toner container opening.
Caution: Do not tilt or turn over the container.
5. Take a new waste toner container out of its package.
6. Insert the new container into position and then push it to make sure that it is firmly seated in place.
7. Close the front cover firmly.
Caution: If the front cover is not completely closed, the machine will not operate.
8. Turn the machine on.
Note: After rebooting, your machine will automatically reset the counter for the waste toner container.
Dec 02, 2010 | Samsung CLX 3160fn All-In-One Printer
Sir, I replace the toner and toner waste container in photo copier Panasonic WORKIO 8020 when the machine is halt and give the msg Replace toner waste container(U14) . But after replacement of...
Try hard reset by turning off machine while it is turned on and pulling the plug. Then press and hold power button for minute or so. replug machine and turn on. If no result try software reinstall and after that you can always contact Panasonic for a hidden code to reset unit to factory defaults.
Sep 01, 2017 | Computers & Internet
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
Where is the waste toner cartridge for a imageRunner 6570
Hello eyoung042,
Let's use standing at the front of the copier as if you were making a copy as a reference. The waste toner bottle at the right rear bottom corner. I'm just guessing the dimensions on the panel that covers it, but I'm thinking 5" x 18"......and is held in place by 2 srcews. Remove that cover and you will see the rather ample waste toner bottle. This machine and its brethren in the newer mid volume machines use an arbitrary value of 250K copies as a signal to show the waste toner almost full message in the display. This is the only criterai used is the meter. I have yet to see a machine where the waste toner bottle was past half full at 250k. But since the copier is using the meter to determine when the bottle needs to emptied, it also means that if you dont reset the counter for the waste toner bottle you will get an E-19 (waste toner bottle full error) even if it is not even close to being full. If you are familliar with sevice mode you can reset the counter, and MUST do so whether you empty the bottle or not in order to make the machine happy again. Press additional functions, then the 2 and 8 together, then additional functions. Press the"copier" block. Then the top right tab on the screen that says "counter" press it. Then press "misc", then press "WASTE TNR". You will notice a counter to the right of this item which reflects the last time the waste toner bottle had been "attended" to.Once you have selected "WASTE-TNR" and it is highlit press the number 0 on the 9 keypad. Then press the "ok" tab at the lower right corner of the display. You should see the counter reset , and now everone can smile. Press reset till you return to the main screen and make another 250,000 copies. Have a good day! ............SPINAL.............
Jul 03, 2008 | Canon IMAGERUNNER 6570 Copier
IR7095 e000019-0000 error
This is the waste toner container and its location.
Jun 24, 2008 | Canon Office Equipment & Supplies
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
Ricoh Aficio CL5000 Laser Printer Logo
462 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
