Question about Apple iPhone Smartphone
Silent mode button broken.
My wifes silent switch on the side of her iPhone was stuck in silent mode....no ringing. The switch was apperently broken and loose. It is repairable, but it will cost you a lot.
BUT you can as a solution do this:
Take a small drill or a small knife (Leatherman micra) and simply try to remove the plastic knob(1.st gen). You can now reach the little sliding switch with a paperclip or similar and get the phone in to NORMAL mode. Don`t recommend to use this feature to switch on/off silent mode, but use volume settings or flightmode to lower ringvolume. Use som scotch-tape to cover the hole where the knob was.
  • Apple Expert
  • 108 Answers
Dont try to take short cuts. They make make things worse. Just send it in to iphone recharge. They can open it and maybe fix it without any parts (cheaper).
Try iphone recharge.
Posted on Aug 12, 2009
  • 100 Answers
You can also buy a replacement switch here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Posted on Aug 19, 2009
Phone become silent. how to change
Anyways if it is android press the volume key at the side or if it is a button phone look for profiles and activate the profile general or loud if it is iPhone. Flip the little switch at the side to toggle between silent and normal volumes hope i helped :)
Aug 12, 2016 | Cell Phones
Iphone won't ring
There is a switch on the left side of the phone, just above the volume buttons. Make sure that it is switched toward the screen. It is easy to push it down by accident and that puts the phone in silent mode.
Oct 25, 2013 | Apple iPhone Smartphone
Vibrate/silent mode button doesn't work
I have the exact same problem with my phone, and you can opt to follow a guide to replace the switch:
(http://modmyi.com/forums/general-iphone-chat/54281-how-fix-broken-ringer-silent-switch.html )
Or you can do what I did and put a little dab of silicon under the switch to hold it up and hopefully keep it in silent mode for you
Oct 18, 2012 | Apple iPhone 3G
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
My iphone will not play any ringtones either dowloaded or pre loaded when a call comes in. It will however play them if i click on them in settings on the phone
Make sure that its not in silent mode.
Silent can be turned ON/OFF by turning the Ring/Silent Switch up/down.
Here's where you'll find the Ring/Silent switch:
Take a look at it and if you see a small red dot, that means you iPhone is in Silent mode. Push the switch upwards to turn the silent mode OFF and to activate your ringer.
Read more iPhone / iPod touch tips by clicking HERE.
or you can visit my blog: Kidstuffs.com
May 18, 2010 | Apple iPhone 3G
IPHONE 3GS wont ring
Check the position of the silent switch. Does it go on and off silent mode when you flip the switch? If not, it's a broken switch. Apple should give you a replacement. If you're out warranty, you can try to open the Headphone jack module that also has the silent switch on it. You can get the part on Ebay or at iPhone Repair and there is a free guide that shows you how to open a kindle and install parts at iPad Repair Guide.
Aug 02, 2009 | Apple iPhone Smartphone
No ringtone when receiving a call
Check if your iPhone is not in silent mode. Push the Ring/Silent switch upwards to turn off silent mode. You'll know that the silent mode is not on when you don't see the small red dot at the Ring/Silent switch which is located just above the volume buttons.
Take a look at this:
for more iPhone / iPod touch tips, click here.
Jan 12, 2009 | Apple iPhone 3G
Hi, i have an iphone 8gb 2g and the silent button is broken and stuck in silent mode, the switch turns easly but it dose not do any thing. is there any way of geting the sound back up, as the mobile wont...
There is a very small switch on the left side of the Iphone, just above the volume lever. if it is accidentally switched down, it will be put on silent mode. Flip it back up and it should be OK.
You will also notice a bell shaped figure appears when you flip it up. When you flip it down, a line will go through the bell letting you know you have set it to silent mode.
Hope this helps
Scott
Oct 04, 2008 | Cell Phones
Iphone silent mode
The best way to fix this is to hold the Power and the Home button for 15 seconds or so, basically hold them both until the Apple Logo reappears. I work at o2 and have seen this problem a few times, its nothing major, just annoying
Hope this helps guys
Alen Boardman
Aug 23, 2008 | Apple iPhone Smartphone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
2,628 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
