Cars & Trucks Logo
Troy Yoder Posted on Mar 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2004 Cadillac SRX six-cylinder issue with security light on church control key stuck in ignition and won't start is there anything I can do
Jacques Valiquette
Level 2:
New Friend:
  • Expert 34 Answers
  • Posted on Mar 15, 2016
Jacques Valiquette
Expert
Level 2:
New Friend:
Answers
34
Questions
0
Helped
5522
Points
104
Please be more specific, can't figure out what "Church? control" means in the sentence.
Jacques.
4 Related Answers
Anonymous
  • 10 Answers
  • Posted on Apr 13, 2010
SOURCE: Starting disabled remove key
VEHICLE ANTI THEFT SYSTEM HAVING PROBLEMS
Anonymous
  • 178 Answers
  • Posted on Apr 03, 2011
SOURCE: I have 2006 Cadillac SRX
may be pressure in the steering wheel or the shifter is not all the way in park try turning the wheel to eliminate any pressure if any and turn the key at same time also try pushing the shifter into park and turn key at same time tilt the steering wheel up or down if none of these works let me know whit more detail on how it started and i'll be as helpful as possible thanks
Anonymous
  • 6468 Answers
  • Posted on Aug 27, 2012
SOURCE: 2004 Cadillac srx key stuck in ignition and loss of power
if the battery is dead then the key will not come out hook up a another car with jumper cables then it will come out
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Apr 17, 2015
SOURCE: I have a cadillac srx 2004..my parking lights wont shut off..even when the key is jn the ignition...why
bad switch
How can I service the theft system on 2004 Cadillac SRX 6 cylinder
now you need the whole antitheft system,all new ignition,keys and fobs,there is a chip on the key and fob,they connect with the module in the ign switch,if the right one,your car will start. http://www.cadillac.com/content/dam/Cadillac/Global/master/nscwebsite/en/home/Owners/Manuals_and_Videos/01_images/2010_cadillac_srx_owners_manual.pdf
newcadillacparts com
3helpful
The car won't start. And I can't get the key out of the ignition.
Likely a worn or damaged ignition lock cylinder,tumblers getting jambed inside.New lock cylinder required.
1helpful
2answers
So I just had my camshaft position sensor replaced, a new timing chain put on, new valves, gaskets, sparplugs, and a new water pump put into my 2004 cadillac cts.. Now that I have my car back my car is...
SOUND LIKE PROBLEM IN THE THEFT SECURITY SYSTEM.IF KEY GETTING STUCK WONT TURN. HAVE GARAGE THAT FIXED YOUR CAR CHECK OUT RESET IGNITION KEY TO THE IMMOBILIZER CONTROL MODULE.BEST TO TAKE TO CADILLAC DEALERSHIP.YOU NEED DIAGNOSTIC GM EQUIPMENT TO WORK ON CADILLACS. MECHANIC WORKED ON YOUR CAR WHEN HE WORKED ON YOUR CAR.HE MORE LIKELY DISCONNECT BATTERY CABLE CAUSING YOUR PCM AND BCM TO LOSE MEMORY.YOU NEED THEFT SECURITY SYSTEM IMMOBILIZER CONTROL MODULE RESET OR REPROGRAM TO THE IGNITION KEYS.
I have 2006 Cadillac SRX and the ignition will not start and the key is stuck. Please advise what it might be. Thanks!
1helpful
CANT REMOVE KEY FROM SRX
Had same problem in '05 srx v6. Dealer said it was ECM (engine control module). It was a recall issue and they replaced at no charge. Vehicle would start and turn off ,but could not remove key from ignition.
1helpful
3answers
My key is stuck in ignition ...anti-theft system engaged...won't release key from ignnition??
2004 SRX I removed the housing around key switch and removed the locking solenoid located under the steering column. I used washers to take up the thickness of the now removed solenoid and replaced the screws. Zip tied the plug to the other wires and re- installed the housing. No more problems. 1 thing. there are 3 screws, 2 holding the lower housing, 1 on the Rt. side that secures the upper housing. That one is hard to find, it's located between the key and steering wheel. The screws that hold the solenoid were very small but easy to use vice grips to back them out.
Key does not come out, car wont start
The key is bounded up in the ignition cylinder from a bent lock tumbler
A new replacement ignition cylinder is the only remedy that will fix this problem
10helpful
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
