Question about DeLonghi Dehumidifiers
DeLonghi Humidistat coils freeze up.
My problem is the coils keep freezing up. Any thing I can do?
Thank you in advance for any help in solving this problem.
Sincerely, Chris
4 Suggested Answers
SOURCE: DeLonghi DEN500P Dehumidifier Humidistat
I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: Delonghi 500p freezes up at
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Jun 10, 2011
heatman101
  • 43501 Answers
SOURCE: The coil is freezing.
Not on all units..
heatman101
Posted on Aug 13, 2011
My DanbyDDR5588RHE has started freezing up. Is there a fix for that?
try to clean the filter and the coils, sounds like it is not getting enough air. Could also be a couple of other things like a bad fan or a bad humidistat
Jul 08, 2014 | Dehumidifiers
The coil is freezing. While it may be a freon problem, isn't there a thermocouple on the coil to detect freezing? Do these things go bad?
Not on all units..
heatman101
Aug 09, 2011 | Dehumidifiers
Delonghi 500p freezes up at bottom left of coil and then does not dehumidify
heatman101
May 29, 2011 | DeLonghi DE500P Dehumidifier
The coil keeps iceing up
is the filter and coil clean? In high humidity the unit mat run too long and freeze. Try turning the humidistat a little lower
Aug 21, 2010 | Oasis Dehumidifiers
Goldstar Dehumidiflier coil freezes
Hi, If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degreesand you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in therefrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make yourdehumidifier work much more effectively.
Aug 11, 2010 | Goldstar DH504EL Dehumidifier
P1 code displayed in LED
Condenser coils do not freeze, it is the evaporator coils that freeze. If it is icing up then the setting is too low for the area it is in, basically the humidistat will never be satisfied so it will run continually and end up freezing the evap coils, the coils could also freeze if the filter is dirty or there is an air flow problem.
Apr 13, 2009 | Dehumidifiers
Danby Dehumidifier Model # DDR557HE Serial # 0107030704369 --Does not collect water and cxontinues to frost up
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
Take care
Mar 23, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Kenmore Dehumidifier won't turn on
The following statement is a parameter for all dehumidifiers and some of the control issues may vary, but the theory is the same.
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
May 13, 2008 | Dehumidifiers
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Nov 10, 2007 | Dehumidifiers
Dehumidifiers Logo
52 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
