Question about Air Tools & Compressors
The compressor is showing ambient temperture to high.
  • 10,865 Answers
The ambient temperature is the temperature of the air in the space around your compressor. If the "room" temperature is too high it will damage the compressor over time. The fix, if this is an actual indoor room would be air conditioning or fans. Outdoors, it can be just too hot to safely and continuously run your compressor.
Posted on Jul 16, 2009
2012 traverse, air conditioner kicking off temperture is hot ,went to auto zone and they put on computer . no codes showed up any help
May be pressure related. They have a pressure sensor that stops the compressor if the pressure gets high. People sometimes make the mistake of adding too much when messing with the AC. Get a qualified mechanic that can work on AC and check the pressure to inspect it.
Apr 15, 2017 | Cars & Trucks
Outside heat stops ac operation
clean coils seee if it makes a difference. all air-conditioners are designed by mfg. to run in a ambient temperture of 95 degrees. after that they lose effiency.
Feb 06, 2014 | Dometic Rooftop RV Air Conditioner
What should the psi be on 1 1/2 ton ac unit?
on r-22 should be 68-74psig on high side 230 to 260psig depending on heat load and ambient temperture
Jul 27, 2012 | Goodman Heating & Cooling
I have a 2001 wrangler with a p1492 code which i know what it is i also just pulled a p0304 code in which i know what that is but does one cause the other
P0304 is misfire #4 cylinder
P1492 - AMBIENT /BATTERY Temperture Sensor To High
no has nothing to do with each other
Feb 07, 2010 | 2005 Jeep Liberty
How do I reset the outside temperture gauge
you can't reset it. Try replacing the sensor.
SECTION 412-04: Control Components 2002 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Ambient Air Temperature Sensor Removal and Installation
  1. Remove the radiator grille. For additional information, refer to Section 501-08 .
  1. Remove the three upper pin-type retainers in the radiator air deflector.
  1. Position forward the air deflector.
  1. Remove the ambient air temperature sensor.
    1. Detach the pin-type retainer.
    1. Disconnect the electrical connector.
    • Remove the ambient air temperature sensor.
Nov 23, 2009 | 2002 Mercury Mountaineer
I'm getting a P4 code & It doesn't blow hot air
P4 code outdoor compressor air exhaust temp too high/outdoor ambient temp too high/ compressor enclosure temp switch break off/module temp too high. Compressor is not running because it has an over temp alarm. Fix/repair thermocoupler
Nov 21, 2009 | AmcorAire UCHW-H18AF2 Split System Air...
The frame around the doors are burning hot
It is normal when the compressor is on.As it prevents condensation at the sides.It depends to the ambient temperture and the warm load inside the refrigerator.as this will lead to higher run times means hot gas is flowing around the corners.
Jun 30, 2009 | Kenmore 53542 / 53544 Side by Side...
What are the high and low pressure specs for my a/c
this really depends on the ambient temp,but as a rule low side 35-45 psi high side 150-170 but this depends on the ambient temp or the temp at the condenser, hope this helps if not get back to me and we'll go from there. please rate my fix as i strive to be the best
May 07, 2009 | 2001 Toyota Celica
2001 f150 5.4l 4x4. Compressor constantly kicks on
yes more than likely your truck is low on 134 but to get the right amount it needs to be sucked out and recharded but i just use a set of a c gauges and kind of guess on the pressures depending on temperture out side. and temperture of the trucks air at the vents the parts stores sell a recharge can with a gauge they can be used also. now just go to the pump and follow the lines and you will find a cap (red or blue ) you want the blue one that is were u can safely charge if there is no caps you will find a couple of nipples you want the one that is greater in diameter.
Mar 01, 2009 | 2001 Ford F150 Styleside SuperCrew
99 olds aurora ac issues
Both switches are simple on/off, so you can test with an ohmmeter or just bypass with a paper clip. See your diagram at the link below.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=17528
Aug 01, 2017 | 1999 Oldsmobile Aurora
Air Tools & Compressors Logo
69 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
