Question about Toro Lawn Mower With Toro Power Tools
It won't start ... hit a board, the blades still turn when I pull to start but it won't start
  • 202 Answers
Check the flywheel key you probally sheared it. be sure to use an oem key to replace it.
Posted on Jul 20, 2009
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
I hit a brick, lawnmower won't move help
check for bent crankshaft at blade connection point. do this by removing spark plug and turn the mower on its side with carburator side up, now spin blade by hand and see if it will spin without a wobble. if it does not want to move, something else inside the engine is damaged and probably not worth fixing. if the blade does not spin true, it is a bent crank and might be able to be straightened by a mechanically inclined person without further damage to the motor. also check to see if the piston is moving while spinning the blade if it will turn at all. R
Sep 02, 2012 | Mtd 22" Yard Machine Push Mower
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Model 917-372832 Eager-1 5.5 HP . Stopped running . Won't restart. I believe the timing may of moved. How to remove the fly wheel to check key position? The key may have stripped. Hit a rock which may...
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Jul 18, 2011 | Craftsman Garden
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I Have a push mower and hit a rock and finished the lawn hearing the lawnmower blade hit underneath a couple of times. When the mower went down slope the blade started really hitting the side. The next...
hi there nchernuka
have you checked that the engine to chassis bolts are still tight and the mounts are ok,
have you checked that you havn't bent the pto shaft ( this will be evident if you remove the blade carrier and blades, then the plug and pull the gine over - check wobble ), check that blade carrier is in good condition and the pto woodruff key is ok and the carrier centre pto bolt is tight
check that anything that is under the mower body is still tightly attached and is not getting swung into the path off the blades - ie catcher tounge - metal body brackets etc
i would also suggest you check the feather timming key in the flywheel too especially if it kicks back when you try to start it
cheers have a look
hope it helps pauly46
May 27, 2011 | Garden
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
My helper was mowing with my Honda push mower.. The handle started shaking.. a lot.. It will start up at first pull but is not cutting well. The blade is turning but the mower is vibrating so much it...
it sounds like the blade may have hit some thing hard .
You say the blade is turning is it turning level or is it sort of swaying as you may have ofset the drive pin.
Worst case.. new mower as it can cost a lot of money to repair drive
I know as i have done the same thing a few years ago
Aug 02, 2010 | Mtd 22" Yard Machine Push Mower
Blade hit curb and was bent replaced blade
TAKE THE SPARK PLUG OUT AND PULL THE CORD A FEW TIMES THEN PUT IT BACK IN AND TRY TO START IT
Mar 20, 2009 | Black & Decker 19" Electric Lawnhog...
Toro Lawn Mower With Toro Power Tools Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
