Question about Refrigerators
Water leaking from the bottom
Ther is water leaking from the bottom on the right side in the front. It is not coming from the Icemaker supply tube
  • 10,865 Answers
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Posted on Jul 16, 2009
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Ice Maker Not Making Ice BUT making a "trying" sound
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 18, 2008 | KitchenAid Architect KBRA20EMSS Bottom...
Ice maker is not working
Jul 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Stop working
Jul 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker will not make ice, but water still comes out cool
Jul 16, 2008 | Whirlpool Refrigerators
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker
Jul 16, 2008 | Refrigerators
Ice maker not working lg double door, freezer draw at the bottom
Jul 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ice maker is not working.
Is there water at your door? Make sure the icemaker arm isn't stuck in any position, be sure it is free to move. Let me know how you make out.
May 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Mar 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
704 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
