Question about Kenmore Dryers
No heat Kenmore Elite electric dryer front loading 1999 runs but no heat
    Brigadier General:
  • 8,619 Answers
Hi!
The issue you are facing is due to the thermal fuse. If the thermal fuse is the problem, the dryer wouldn’t run.
First of all verify the voltage for the dryer by using multi-meter to measure the voltage at the dryer outlet to make sure you have 240v because the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the voltage is ok, then the most likely bad parts are given below. As always, you should use your meter and the tech sheet supplied with your dryer (hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
You need to check and replaced the bad parts to resolve the issue you are facing with.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 16, 2009
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Dryer is not heating properly have run loads two to three times. Can I just replace heating element?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 09, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer wont heat
heater element needs repair but usually replacement
Jul 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Kenmore front load dry no heat
could be thermal fuse or heat element
Mar 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore series 90 no heat
Check the glow ignitor on the right side of the dryer if you are looking at the front on the bottom side and make sure that it is not cracked
Feb 09, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't heat
The voltage first a unit needs 220v to heat but only 110v to run check for proper voltage at the plug first
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Mar 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
139 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
