Question about Air Tools & Compressors
How much oil is needed to change oil - Air Tools & Compressors
    Sergeant:
    Champion:
  • 226 Answers
15 to 35 ounces depending on your make and model
Posted on Jul 19, 2009
Why is my oil life percent is 9 and can I drive still or I have to change engine oil soon for the mercury mountaineer 2006
Regular maintenance is needed for oil changes. If your oil level is dropping you need to keep it up to operating level but you do need to find out why it is burning or losing oil. If your oil is black then it needs to be changed regardless of the miles on it.
Apr 20, 2014 | 2006 Mercury Mountaineer
Hi, today i have checked the transmittion oil level, it was good but the guy tell me that the oil become black & its appear burn, do i need to change the oil? if so do i need to change the filter...
You need to change black oil and its filter as well. You need to do it periodically. Refer to your manual on oil & filter change interval. Regards
Apr 20, 2011 | Chevrolet Express Cars & Trucks
Im changing oil on 05 rmz 450. i need to know oil capacity and where the oil filter is located
when changing both oil and filter use 1450mls of oil if only oil change use 1400mls but always check oil level after change
Sep 30, 2010 | 2005 Suzuki RM-Z 450
My lifter are loose or need changing
put some diesel in the oil about a half a pint ,3 sec squirt of fairy and then run engine for a couple of days normal use ,then drain oil and use the cheapest diesel oil you can buy ,after a month change the oil and filter and your hydraulic tappets should be nice and quiet,then make sure you change oil every 6000miles and a oil filter every third oil change and no silly long life semi this or that oil ,just the cheapest 20/50 diesel engine oil .
Jan 19, 2010 | 2000 Mitsubishi Galant
How often do it need an tune up,oil change engine coolant and brakes changed?wen to check the oil
this depends on how you drive and how many miles you have on your car and what type oil you are using, on a 1994 you should do a tune up every 30 to 40 thousand miles. You need to do a engine clean then change oil. if you use a good quality oil you can go every 3 to 5 thousand miles on changing oil. You need to change the oil in the drive train after 30 thousand miles and the transmission oil and filter should be changed every 30 thousand miles. Also the Thermostat and antifreeze should be changed every two years to make sure the anti freeze is still lubricating the water pump. Failure to change antifreeze has burt up more engines than I can recall. Check oil in the morning when cold. Check the transmission oil when hot and in park. If you want more detailed information post here.
Sep 29, 2009 | 1994 Ford Thunderbird
My oil light is on, i have 39 miles on my gsxr 600. do i need an oil change or do i need to put oil in
Don't listen to the idot that said to change your oil at 39 miles! If you only have 39 miles on your bike and your oil light is on it mean there is low oil pressure so you need more oil in it. Cause the only reason that light goes on is when theres not enough oil in it. Not because you need an oil change.Also the oil change should be done at least every 3,000 miles but I do mine at 2,500. Also When you change the oil for the first time, you want to change the Filter as well. Every oil change there after you dont have to change the filter every time, you can do it every other oil change if you choose to. And always fill it up to in between the lines of your sight glass. and always makesure that after you put oil in it you start it up and for about 30-60 seconds then shut off and let sit for about an hour and add oil as needed.
Sep 18, 2009 | 2008 Suzuki GSX-R 600
Oil change
Need 4 quarts of oil. 5W30 Thiner oil then 10W30 your choise and don't forget to change the oil filter too.
Good luck. and hope this helps
Apr 09, 2009 | 1993 Oldsmobile Achieva
No problem, just question on oil change,
I would recommend that you change your oil every 3,000 mile or 3 months which ever come first. This just help you keep a cleaner engine and keeps oil at Peak performance and provide excellent protection against sludge which developes with lack of oil change. Once a year seems too long for an oil change. However between oil changes you can add oil if needed. Good luck and thanks for using FIX YA
Jan 26, 2009 | 2006 Buick Lucerne
2000 Toyota Camry Oil Change
I am assuming that you will be changing the oil filter aswell
if your engine is a 3L you will need 4.7 of Oil
If your engine is a 2.2L you will need 3.9 L of oil
Sep 05, 2008 | 2000 Toyota Camry
Air Tools & Compressors Logo
61 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
