Question about Maytag MAH8700A Front Load Washer
E3 error code and a lot of vibration when working. I had a technician check the unit and the E3 error code is for the motor. The motor is working fine though and the tech said I needed a new control board. Does anyone know the part number for this control board or if this is the problem.
    President:
  • 1,197 Answers
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
3. A poor connection – Check wire harness connector to motor. Unplug connector and pull on each wire. If a wire connector comes loose from the plug, bend locking tab up
NOTE: If a locking tab is not properly seated in the plug connector, the terminals will not fully engage as the connector is plugged into the Motor Terminal Block. Inspect the terminals on the motor side of the connector. Straighten any bent terminals if they exist. Recheck the harness side of the terminal block if any bent terminals are found. Bent terminals can indicate a problem with the locking tab inside the plug
Reconnect harness plug to Motor Terminal Block. Run washer through a quick service cycle (wash and spin) to check motor operation.
see if that helps..... else u might have to replace the board....
the manufacturers number for ur model is 34001496
thank you for using Fixya
have a nice day
Posted on Jul 16, 2009
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
MY SAMSUNG WASHER HAS AN ERROR MESSAGE THAT SAYS E3 AND IT WONT SPIN
This video will help you diagnose the fault on 3e error codes and the video will help you solve the problem hope it helps
Jul 08, 2014 | Samsung WF337AA Front Load Washer
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
My unit trips off and shows E3 on the screen
E-3. INDOOR FAN MECHANISM LOCKED/ No power to F.Motor. Check motor by rotating manually. If hard, replace motor. Or PCB defective.
Jan 12, 2011 | Carrier Heating & Cooling
Error code in the top zone E3
An E-3 error code on your product indicates a problem with the DC fan in the upper zone. Your issue could be with the fan motor, control board or connecting wire harness. A DC motor can not be ohmed out like an AC motor, so if you detrmine the motor is not running, check for DC voltafe at the motor connections. If there is 12 to 24VDC, then you have a bad motor. If no voltage is present, check the output on the board. Before replacing an expensive circuit board, you may want to have a professional service tech come out and diagnose your problem. ***ALWAYS remove electrical power from the product when removing panels to gain access to components, and also when putting the panels back in place.
Nov 04, 2009 | Magic Chef Refrigerators
We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
E3 The washer vibrates
hi.....
the following table provides you the all error codes and the reason causing those error codes.....
Washing Machine Failure
Code
Condition Check/Repair F1 Water supply/low water fill · Check water supply to machine
·Replace water inlet valve F2 Water level too high · Plugged/Bad water pump
· Faulty water valve F3 Pump problem Check pump trap and clean. F4 Thermistor problem · Open thermistor, replace
· Bad wiring to thermistor F5 Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes · Check heating element
· Check thermostat F6 Motor fault · Check wiring to motor
· Replace motor if necessary F7 Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid 00 00 Machine did not spin Check load for out of balance Redistribute load and restart i think my solution will be definitely will be helping you......if you are satisfied with my solution then rate for me...
thank you for using fixya....
Jul 20, 2009 | Samsung Washing Machines
Code E3
The Machine control is attempting to drive the motor but is not seeing any tachometer response or motor action. It could have a failed tachometer/hall sensor which is part of the motor, failed motor or machine control. It could be a loose wire connection at the motor or at the machine control board. This type of failure will require a technician to diagnose and repair your washer. I recommend calling a service technician.
Jan 10, 2009 | Washing Machines
Error Code E3
I have the same type of Aprilaire humidifier unit with automatic temperature sensing control. My unit also displayed the 'E3' code. The HVAC technician was on site today and replaced the temperature sensing unit that is located outside the house. The humidifier is functioning normally once again.
Dec 03, 2008 | Aprilaire 600 Humidifier
Maytag MAH8700A Front Load Washer Logo
728 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
