I have an LG SteamWasher that is displaying the OE error. My wife had washed a pillow that apparently had a tear somewhere and leaked a bunch of (this is a guess) soft cotton material into the washer. I drained the washer using the front access, then cleaned a bunch of this stuff out of the filter. Ran it again. It ran partially through the cycle and displayed the OE again....not unexpected. Repeated the drain/filter procedure and removed a bit more of this fiber. Now when I run the machine, the wash cycle never begins. It sticks on whatever the initial starting time is (say 55) and doesn't begin injecting water into the drum. Eventually comes back to the OE error. I think that I have gotten all of the fiber out. Is there potentially something clogged on the rear drain or has this stuff messed up the pump. Any help would be GREATLY appreciated.
  • jqua Jul 16, 2009
    Is the filter on the front of the machine the only one I need to clear? I just want to make sure that I am not missing something with the drain hose on the back of the machine..
  • 15,935 Answers
OE Error means drain error (outlet error)
Possible causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
If you have cleared the filter multiple times - most likely there are fibers stuck in the impeller.
This will require removal of the pump to clear the debris (most likely wrapped around the impeller.
Thanks for using FixYa - please accept this answer to remove it from the work queue.
:D
Posted on Jul 16, 2009
  • blueextc3221
    blueextc3221 Jul 16, 2009
    no - thats the only one :D
Water won't drain and it says oe
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
IT DON'T GO THROUGH CYCLES COME UP WITH A CODE OE
Kevin
Jan 06, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The washer is displaying an OE. How do I fix this?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer machine erroe code oe
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Clean and straighten the drain hose / clean the drain filter.
Jun 30, 2010 | LG WM2688HWM TROMM SteamWasher
I have an LG TROMM wm1812cw washer. Out of the blue the machine will not spin or drain. It has given an an error code OE
Sep 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
