Question about Ovens
How do you access and replace the hidden oven element in a Electrolux/Frigidaire Galley 30 single electric convection wall oven? Model # FGEW3065KWA
There are no error codes. Broil works, the safety is not popped, tried the control board - not it. Oven heats to temp and takes a long time because I think it uses both broil and bake elements to preheat, but only broil is doing the work. When it reaches desired temp the oven temp just falls although the control board looks like the temp is correct and looks like the board and thermostat are calling for the bake element to come on properly. I think in the bake mode, only the bake element maintains the heat. Can't see how to get in there. Also there is a small hole in the bottom of the oven is there a way to patch or replace?
    Top Expert:
  • Ovens Master
  • 85,108 Answers
There is no such thing as a hidden heating element.
Posted on Jul 08, 2018
4 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Posted on Dec 30, 2007
hbsurfdawg
  • 95 Answers
SOURCE: heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Posted on Mar 02, 2009
emissionwiz
  • 85108 Answers
SOURCE: frigidaire DGES388DS2 electric single oven
Did you reset the house circuit breaker that supplies power to the oven?
Posted on Apr 24, 2012
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
How to test oven control board on a Frigidaire FEF366DBE?
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Nov 16, 2014 | Ovens
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
How do I fix Error F 11 on Electrolux wall oven E30EW75ESS2?
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 08, 2013 | Electrolux 30" Built-In Single Electric...
I have a Frigidaire Electrolux Model FEB30S5ABB. The oven will not heat up to the correct temperature and the bottom element is not turning on. We checked the element at it checks out ok. What could be...
Hello lizzyd62 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately.
Nov 23, 2012 | Frigidaire 30 in. Electric Single...
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
My oven is not heating
its the element .get your model no and find it on e bay which will prob be the cheapest place
Sep 18, 2012 | Electrolux 30" Built-In Single Electric...
My electrolux oven is ruined because of a oven mat--is their any paint I can use to cover the floor of the oven so it look even?
no
ovens operate well outside any paint heat range and paint fumes will spoil what is cooking
there are 2 fixes
1--- new oven internals
2--new stove
Jan 06, 2018 | Electrolux 30" Built-In Double Electric...
Ovens Logo
232 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
