Question about Dryers
THE DRYER WILL HEAT BUT THE DRUM WILL NOT TURN. I HAVE CHECKED THE BELT AND IT IS OK. NOW WHAT
  • 10,865 Answers
Hello. I can help you. Since the belt is ok there are only two other possible problems:
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on Jul 16, 2009
Candy dryer goc 590c
There may be a loose belt or the drum may be stuck with sticky stuff and needs cleaning.
Sep 05, 2014 | Dryers
Just fitted a new belt to my dryer now it wont turn have checked for any loose wires
Are you sure you have the belt on correctly? When you start it does the motor run or try to run? Does it hum or buzz when trying to start? Take the belt off & start it see if the motor runs if it does check if drum, belt and idler pully are installed correctly.
Check the drum rollers and drum glides be sure the drum turns ok. Be sure everything is installed correctly & turns OK . Are you getting power? Hard to tell what is wrong without much information about what is going on. You might check the front panel & see if it is binding on the drum not letting it turn. Hope there's something here that will help you.
Jun 02, 2014 | Frigidaire Electric Dryer
Dryer works,drum doesn't
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 04, 2010 | LG DLE0442 Electric Dryer
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Dryer heat but what turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Mar 28, 2009 | AEG T57800 Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
KENMORE DRYER PART NO 696891
are you sure belt not broke remove screws under lint screen and pull top up by releasing clips under edge each corner..is motor running ? also belt may have jumped off idler pulley and motor pulley remove front panel to ck
Oct 24, 2008 | Dryers
GE Electric Dryer Older model
it could be the motor capacitor. to check, turn on and carefully give the drum a push in the direction of rotation. if the drum picks up speed and goea ok, then the motor capacitor is faulty. cheap part
Jun 26, 2008 | Dryers
Dryers Logo
153 people viewed this question
Top Dryers Experts
