Question about Sewing Machines
Brother nx450q won't thread needle - Sewing Machines
  • john_froncze Jul 18, 2009
    the pin is no where near the hole in the needle. is it possible that it came disconnected. it just flops around. does the pin go through a hole , the one with the bronze bushing. i can't me bending the pin helping at all.
    Sniper:
  • 52 Answers
Get a magnify glass and slowly lower the needle threader down to the needle and see if the pin is going through the eye of the needle if its just missing you can bend it slightly to either side
Posted on Jul 16, 2009
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
I have a brother pe300s , the problem is it won't catch bottom thread
Please change your needle. It is likely that the one you have in the machine is either not fully seated into the needle bar... or it is bent or damaged in someway. Also please double check to make sure the needles you are using are suitable for your machine.
Aug 20, 2012 | Brother Sewing Machines
Sewing machine needle won't go down to catch bobbin thread
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly
also make sure the thread has not come off the thread take up lever
if none of these suggestions help, then you should consider
taking the machine to have it service, to see if it's out of time
Jul 31, 2012 | Brother Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
The bobbin thread wont come up when lowering the needle
The bottom thread won't come up?
Make sure you:
-Have the top threaded and through the eye of the needle (Basics are best to check, I've missed it once or twice! lol)
-Are holding the tail of the top thread when you lower your needle and pull it back up (Hold it too tight though, and it might not grab)
-Have an inch or two of "tail" or extra thread for the needle to grab on your bobbin thread (sometimes it won't grab if there's not much there)
-Have all your lower pieces in and secure. (Mine tend to jump around if I'm not putting 'em in right)
If it's still not grabbing, I'm not sure. Sorry, hope it helps.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
Brother pe 150 needle wont pick up thread from bobbin changed needle
Check that the needle is in the right way, flat shank to the back. If it is around backwards, the shuttle hook won't be catching the thread at the back of the needle to form the stitch.
Jun 22, 2011 | White Sewing White 3032
Problem with my machine
l have a pe-200 brother machine and the needle won't go down and is making a noise can anyone help .l have checked belt and that's fine thanks
Dec 11, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
149 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
