99 cadillac the AC don't blow on the vents only windshield.
    Scholar:
  • 56 Answers
Seems like the Switch is bad.
The switch Could be bad or the Motor for Switching from the defrost to the passanger must be bad.
Things wear out and could you check these items, Hot cold switch and watch what it does. The rear defrost button, the recirculating button, the Outside air button, and A.c button. If a combination of these buttons and switches do not work or actuate their respective commands then you should replace the switch. If it only the Defrost switch then you should have a Certified Tech check it out. Removing the dash is not a task for the average joe. Thanks and hope this Helps thank you for your question.
Posted on Jul 17, 2009
Climate Control A/C that constantly blows on windshield after coolant hose steaming leak.
You probably disconnected a vacuum hose that didn't get reconnected. The mode doors are controlled by vacuum and the default id the defrost mode.
Mar 08, 2015 | 1991 Cadillac Fleetwood
On a 1998 STS Cadillac is the air mixing box and actuatordoor under the dash behind glovebox?
many cars automatically kick on the air compressor in defrost, to dehumidify the cabin air
Jan 03, 2015 | 1998 Cadillac Seville
Air blend door actuator
Possible bad blend door actuator .some gm cars can be relearned to the new climate control head
Jul 28, 2013 | 2001 Oldsmobile Aurora
1977 deville top ac vents not blowing; only floor vents blowing cold air.
vacum hose leaking or not functioning at all trap door to left of glove box in dash
Aug 08, 2012 | Cooling System for Cadillac Sedan DeVille
The fan will blow at the windshield for most of
you should know this is easy problem , open up the control AC/blower device and melt with soldering all points over the circuit it's easy don't be scary
May 24, 2010 | 2006 Ford Crown Victoria
Ac not blowing on the front vents
The most likely cause would be a problem with the vaccuum source. Most vehicles use a vaccuum source from the engine, in order to control the Climate Control mode. The default setting is for the Climate Control is for it to return to the defrost mode when there is no vaccuum. I'll bet that there is a bad vaccuum hose is leaking or has become disconnected.
Aug 27, 2009 | 1996 Cadillac DeVille
Ac vents
One of the temperature actuators are not working it has 2, one for each side.
Jun 28, 2009 | 2004 Cadillac Escalade
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
