Question about Kenmore Oasis HE 27082 Top Load Washer
Oasis HE washer stop working filled with water beeps with a display code LD
  • Kenmore Master
  • 3,361 Answers
You have something stuck in the drain pump/filter. Remove the pump filter and clear the blockage.
Posted on Jul 16, 2009
I had this problem and it turned out to be a broken blue lead to the pump (2 leads). The wires are connected by a very sharp prong type connector that sometimes cuts into the wire too deeply and severs it after some vibration or the tub bouncing around. Just take the existing severed wire out, and re-insert the lead in the connector.
Posted on Oct 06, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Cabrio is showing "LD" in the display code and
you need to check your main drain pump for anything that may be restricting the water flow or stopping the impellar wheel from turning
Nov 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What does LD mean in the LED time screen? it fills for a min then stops and flashes Ld
Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Jul 28, 2009 | Kenmore Elite 45986 Front Load Washer
My washer stops at the spin cycle. The LD code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
251 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
