Question about mares JUBILEE Buoyancy Compensator
Dacor/Mares Airtrim I have a Dacor airtrim and the inflate works, but the deflate does not. Is that a sticking valve? ow do I fix it? Thanks
  • 60 Answers
The Mares power deflate system relies on the pressure of water squeezing against it to deflate. That is to say it only works when you are under water. On the surface you will have to squeeze the jacket whilst pressing the button. Hope that helps.
Posted on Nov 10, 2010
  • 121 Answers
Which deflate?? Could just be it needs a service.. Has it had one recently??
Posted on Oct 21, 2009
How do I deflate spa
To deflate the portable Therapure spa 050006 is easy. The trick is to realize that the black valve used to inflate is in fact a double valve. Remove the square threaded cap to inflate it.
1. To deflate the spa leave the black square threaded cap and below that you should find a round or winged coupler.
2. Unscrew this coupler off and immediately the air will start to escape. It shouldn't take more than about 2 minutes to deflate and you are ready to pack it away.
3. Return the valve (before doing so you could use a vacuum to suck out as much air as possible.)
4. Lay out the spa floor in a circle
5. Fold the three sides to the centre
6. Then lay the power unit on the folded sides.
7. Remove the coupler one more time to squeeze out any remaining air and then return it.
8. Roll the up the side to the original size of the spa before you opened it the first time.
Sep 18, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
How do I inflate/deflate my water trampoline?
You can inflate your water trampoline with either an electric pump or a manual pump. I suggest using an electric pump because it will save you a lot of time and effort. In terms of deflating, you also have 2 options. You can simply open the air valve and allow the tube to self-deflate or use a two-way air pump to remove the air.
Jul 31, 2012 | Sport & Outdoor - Others
Just got a Skedaddle 2 XC Inflatable Kayak and having trouble trying to inflate it at home to see how it works before going out on the water. Don't know which tip to use on the foot pump or where to use it...
Use the threaded tip for the two main chambers, but be sure to turn the inside part of these valves clockwise to put them in the inflate position -- just press your finger on the valve and turn (the instructions aren't very clear on this). To deflate, push the valves in and turn counterclockwise.
For the orange twist valves use the tip that fits over them -- there is only one that fits snugly over them. Don't forget to open the valves (turn counterclockwise) before inflating and then close them (clockwise) before removing the tip. Just turn then cc to deflate when you're ready to put the kayak away.
I was able to inflate the Skedaddle 2 in less than 7 minutes on my second try, and I wasn't rushing at all. It's really pretty easy once you get the hang of it.
Mar 20, 2011 | West Marine Skedaddle 2-XC Two-Person...
Discovery Kids Inflatable Sprinkler Globe. Problem: We can't deflate ours! I no longer have the instructions (and can't find them online). You'd think you could just open up the plastic tab and maybe...
When squeezing the valve, is the flap at the bottom of the valve opening? This is usually the cause of this problem. Sometimes these valves need to be pinched while pressure is applied to the item to force the air out.
Does your air pump also vacuum? Many electric air pumps have 2 attach points - air 'out' to inflate and air 'in' to deflate. For largef items, this is much more efficient for deflating.
Oct 04, 2010 | Toys
H2o0008 inflator regulator will not fit on Mares BC
have u tryed changing out you regs inflator line one should have came with your bc
May 17, 2009 | Scuba Diving & Snorkeling
My airride on 2000 lincoln navigator will inflate but not deflate
MY 2000 LINCOLN CONT INFLATED A MONTH AGO AND WILL NOT DEFLATE. THE LIGHT COMES ON SAYING CHECK AIR RIDE SYSTEMS. HOW DO I DEFLATE?
Apr 11, 2009 | 1999 Lincoln Navigator
I have a Dacor airtrim BC. The oral inflate tube checkvalve is leaking. I need a new valve.
it may be dirty. you can unscrew the valve and see if any dirt or sand is keeping it from sealing.
Jan 05, 2009 | mares JUBILEE Buoyancy Compensator
Dacor Viper regulator leaks water
Pressure inside 2nd stage should be the same as ambient so no water should enter. Maybe should adjust to freeflow and then a nough
back until free flow just stop. careful your reg will now be very sensitive.
Another problem could be a worn exhaust valve - change a new one, see if it helps.
Good luck,
Eddie Foo (Malaysia)
Jan 01, 2009 | Dacor Viper Tec Scuba Regulator
mares JUBILEE Buoyancy Compensator Logo
532 people viewed this question
Top mares Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a mares Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
