Question about Dryers
Squeal noise from the dryer
My ge dryer model DDE 5300 has a squeal noise as it rotates while drying. I know it's old but is there an easy fix
    Problem Solver:
  • 5 Answers
Check the belt tention. or you may need to lubricate the wheels the drum sits on.
Posted on Jul 16, 2009
We have a General Electric Dryer, Model # DDE 5300 GBLWH.WE KEEP GETTING WHAT LOOKS LIKE OIL STAINS IN THE CLOTHS .IT NOT THE WASHER THATS A GE TOO .
There could be some rubber/plastic or other contaminants in the drum, that leach on to your clothes when the dryer heats up. It's possible that some oil got on the felt seal that goes around your drum.
Nov 15, 2015 | GE Dryers
What's your problem?Squealing Speed Queen dryer
The drum of the dryer has a belt that turns the drum while in operation. These belts are not hard to replace and if your old belt is still attached you can visually see how it is positioned on the drum. However, there are also at least three rollers that carry the drum allowing it to rotate as it is being turned by the belt. These rollers are also not that expensive and are relatively easy to replace. Since the machine is 20 years old you may experience some problems finding the parts (maybe not)> You can check with the company via the internet and find out. Just give them the model number and a description of the part. The pulley that is attached to the shaft of the motor that drives the belt that turns the drum could also be worn out. Replacing the pulley on a machine that old can be trying but not impossible. If you have a technician check out and make repairs on these potential problems it probably cost well over $180 but if you have any mechanical ability you can probably do the job yourself if you can locate the parts. Just make sure the machine is unplugged from an electrical source before removing the back and the rest is just work.
Dec 12, 2011 | Speed Queen Dryers
Our DDE 5300 GBLAD dryer makes a rumbling, thunder-type noise after it's been drying clothes for awhile. What is wrong?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them then you will need to replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 15, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
My GE Dryer dries but only after a longer time than before
One of your heating element is probably out of commission. You can replace it cheap. Here's how:
SOME REPAIR PICTURE
Dec 16, 2009 | GE DBSR453EBWW Electric Dryer
Squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Nov 16, 2009 | AEG T58840 Dryer Electric
I have a Maytag Dryer MDE9806AYW Intelli Dry SQUEALS
Yes its worth repairing, it sounds like a simple fix, could be pulley, or seal replacement but for the price of some machine oil, or part, well worth it. The intelli dry pulls apart from front, with the door and top is hinged. A little time consumeing but I think still worth it.
Feb 04, 2009 | GE DBSR453EBWW Electric Dryer
Loud Grinding noise in Dryer
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Dec 29, 2008 | GE DSXH47EGWW Electric Dryer
Noise from timer occurs on ocasions when dryer won't start
well lol its hard to bury an old friend lol will try to help what kind of noise are you hearing sure you dont want to get six of your friends to carrey it out lol tell me as much as ya can
Dec 30, 2007 | Dryers
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
326 people viewed this question
Top Dryers Experts
