Question about Amana Kitchen Ranges
My amana cook stove oven will not light. all other burner work fine
Set oven to 375 green light for oven and preheat light, but oven does not light.
    Social Butterfly:
    An expert who has shared 10 answers on their Facebook wall.
    Habit-Forming:
  • 114 Answers
I don't know about stove's
Posted on Mar 14, 2016
SOURCE:
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
    Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
    Feb 05, 2010 | Amana Ovens
    Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
    This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
    Jan 14, 2010 | Amana Ovens
    Xl44 oven burner pulses, doesnt properly heat up.
    it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
    Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    I have a an AMANA gas stove burners work but oven doesn't
    First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
    make sure gas is getting to burner when called for by the thermostat or oven control..
    Jun 11, 2009 | Ovens
    Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
    the oven safty valve is goin bad. that the part that most oven burners sits on.
    Dec 09, 2008 | Amana ARGS7650SS Gas Kitchen Range
    Amana Convection oven not controlling temp
    I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
    Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
    Kitchen Ranges Logo
    61 people viewed this question
    Top Amana Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Archie Ferrarini
    Archie Ferrarini
    Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
