Southwestern Bell FM-2552BS (014337903477) Corded Phone Logo
C
Candace Posted on Mar 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I ADJUST THE RINGER VOLUME - Southwestern Bell FM-2552BS (014337903477) Corded Phone
NoName Jack
Level 3:
  • Master 1,150 Answers
  • Posted on Mar 14, 2016
NoName Jack
Master
Level 3:
Answers
1150
Questions
Helped
232910
Points
4657
Hi Candace
Perhaps these videos may help
cordless phone ringtone YouTube
How do you turn the ringer on/off on aatt 993 2 line phone
If you mean the AT&T 993 two-line speakerphone, you can adjust the ringer volume for each line when the phone is not in use. To increase the ringer volume on the primary line (if set), press the Volume Up arrow. To decrease the ringer volume, press the down arrow. There are 8 different volume levels available for the ringer. The Volume Up/Down buttons are below the * and 0 keys.
To adjust the ringer volume on the secondary line, press that line button (between the Conference and Hold buttons) and then press the Volume Up or Down buttons as needed. (If you haven't programmed a primary line, press a Line button and adjust that line's ring volume before pressing the other Line button. Then adjust the volume for that Line.)
I hope this helps. These directions are shown on page 32 of the manual. AT&T currently has the manual here : https://att.vtp-media.com/ecp/documents/product_Product/227/UserManual/5596/993_manual_i14.pdf . To find this manual or other AT&T phone manuals, start here: https://telephones.att.com/product-support/manuals .
How do I adjust ringer volume on wired ATT two Line phone model 993
VOLUME buttons;
During a call, press to adjust the listening volume.
While the telephone is not in use, press to adjust ringer volume.
2helpful
How do i adjust the volume on my phone, not ringer, but voice volume?
While you're in the middle of a call use the same button to adjust the ringer volume. It should only adjust the in call volume.
6helpful
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
2helpful
How to increase ringer volume of panasonic kx-tc2100bx model cordless phone
Go to Menu > Ringer Setting >Ringer Volume > use Right or Left arrow to adjust the volume of the ringer
thank you
I cant turn up the volume on the second cordless phone. how is this done/
Do you want to turn up the ringer volume or the call volume?
To adjust the volume of the ringer press the UP or DOWN arrow on the pad to bring up the main menu. Move to the 'Handset setup' icon and press OK. Select 'Ringer Setup' and press OK. Now select 'Ringer Volume' and OK. (At this point if you have 2 incoming lines you will need to select the correct line). The display will now show the volume, use the UP and DOWN arrows to adjust the volume. When finished press the OK button, then press the CALL END button to return to the main screen.
Adjusting the call volume is easier. When you are on a call use the UP and DOWN arrows to alter the volume.
I hope this helps.
1helpful
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
3helpful
Lucent 854 phone, how do we turn up the ringer?
To Adjust Ringer Volume:
1) Press CONF, then using the dialpad press either 1, 2, 3 or 4 to indicate which line you want to adjust.
2) Press one of the VOLUME buttons to increase or decrease the ringer volume.
To Turn the Ringer Off
1) Press CONF
2) Use the dialpad, press 1, 2, 3, or 4 to indicate which line you want to adjust
3) Press the down VOLUME until you no longer hear a tone.
12helpful
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Top Southwestern Bell Lands Phones Experts
k24674
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
