Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My USB plug is not working, and i don't seem to know the problem.
When i first bought it, the USB plug was still working, around the next 3 weeks, the computer couldn't detect the device
    Sergeant:
  • 361 Answers
It means your usb driver is not stall or dileted. right mouse lick on computer click on device manager. then look on univesal. usb port if there yellow sign . kee bord driver cd and right mouse click .on it.. then if yell sign hidden .softwere is stall. if not stall your bord usb port mabe damage keep usb card in mother board slaut to chek thanks (nepal)
Posted on Jul 16, 2009
  • Roshan Rijal
    Roshan Rijal Jul 16, 2009
    it means your usb driver is not stall or dileted. right mouse lick on computer click on device manager. then look on univesal. usb port if there yellow sign . kee bord driver cd and right mouse click .on it.. then if yell sign hidden .softwere is stall. if not stall your bord usb port mabe damage keep usb card in mother board slaut to chek thanks (nepal)
  • 22 Answers
First, be sure that you have tested the drive on another known functional USB port on the computer and another computer. If the drive doesn't work there, then it is a problem with the drive or cable. If this doesn't work see below.
Go to control panel>System>Device Manager and check to see if you have yellow question mark. If you do you will need to remove it and try to replug the drive. This may be a driver issue. Also check the BIOS and see if it has been disabled there. If you have done this then do the following.
You will need to go to control panel>System>Device Manager and remove all USB components and the right click the top of the tree and select scan for hardware changes. The USB should reinstall and be ready to go.
My mic recently has just stopped working
I don't want to insult your intelligence but experience makes me ask, 1 be sure it isn't muted in your audio board program and 2 make sure you didn't plug it I to the speaker jack or another jack by mistake.
Apr 03, 2015 | DreamGear Prime Solo Black Wired Gaming...
I have a 2001 CRV. The replacement alternator has 4 prong plug. The one on the car has a green 3 prong plug?
Here's the problem:
http://honda-tech.com/showthread.php?t=2624894
Sounds like you have a Canadian SiR harness (all Candian 6th gen civics use a 3 wire alternator plug instead of the USDM 4 wire setup, IIRC its because the Canadian civics don't have an ELD) easiest thing to do in this situation is to reuse the original SiR alternator.
Don't know where you live or where you bought the vehicle but it's Canadian. Next time you need parts be sure and tell your supplier that it needs Canadian parts.
Oct 05, 2012 | Honda Alternator Crv 1999 99 2000 00 2001...
I have an 2000 ford crown victoria interceptor that was showing a po301 misfire after I had installed a new cop the night before. So I decided to switch the cylinder one cop and plug to cylinder two and...
Absolutely. But check connections first. Also, did it come with a new boot. If not replace it. Do your swap test again, and you'll know for sure.
Oct 22, 2011 | 2000 Ford Crown Victoria
I have a problem,I bought a apple i pod mp 3 player a few weeks ago at a flee market,worked fine up until last night I accidently went into lock screen and it went off and now I don't have a clue to...
There are 2 ways to try and unlock it if you don't know the passcode.
1) Connect your iPod to the computer set as the primary one in iTunes. Open the iTunes application, then disconnect your iPod from the computer, and it should no longer be locked.
Only use this next option as a last resort because it is a destructive process.
Everything on your iPod will be erased.
http://support.apple.com/kb/HT1339?viewlocale=en_US
Aug 25, 2011 | Apple iPod nano
Dual Shock 3 Doesn't seem to work at all
i have the perfect solution...
step 1- plug usb into controller, make sure the system is off
step 2- press thee reset button on the back of the controller then turn your system on with the systems on-button
step 3- once the system is on, press the ps button.
step 4- remove the usb and then pres ps again
step 5- it workz, gud lukk!
Apr 12, 2009 | Sony Dual Shock 3 Controller for...
Razer copperhead problem
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
Feb 18, 2008 | Razer RZ01050300 Mouse
Mx518 cable problem
Most PC repair shops can make you a new one.
The mouse itself is only around £20.00 / $40.00
Jan 13, 2008 | Logitech MX518 931352-0403 Mouse
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
I'm not a blonde- but the damn GE Easycam is making me crazy.
Marueen, GE computer accessories are now sold and supported by Jasco. Their download page has drivers for your webcam; unfortunately they don?t have any Vista certified drivers. Unfortunately lots of hardware manufacturers are not creating new Vista capable drivers for older equipment and I suspect Jasco will follow the trend as well. You can try downloading the latest XP driver from their site and seeing how it works but in the long run you may just be better off getting a more mainstream product with Vista drivers. Jasco download page: http://www.jascoproducts.com/cgi-local/SoftCart.exe/online-store/scstore/pro/computer_software_cams.html?L+scstore+ndrt4702ffcebece Let us know if you have any other questions and please don?t forget to rate this post.
Apr 03, 2007 | GE EasyCam Webcam
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
592 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
