Question about Emerson Televison & Video
My 32in emerson lf320em4a led tv screen won't come on, the back light powers up And the power button flashes? Please help.
    Social Butterfly:
    An expert who has shared 10 answers on their Facebook wall.
    Habit-Forming:
  • 114 Answers
Call someone or experts
Posted on Mar 14, 2016
I have an Emerson tv 32in model no. Lf320em4a it’s about 3yrs old it won’t turn on the screen starts and shows the Emerson name then shuts off.is there a fuse or etc or is it just shot
Check your voltages when you power it on compared to when it shuts down...see what rail is dropping off for starters, then I can give you more of an idea where the issues are at..I have a feeling you have inverter issues because this was a common failure on this set check and see what voltages drop off after the startup screen
Apr 03, 2018 | Emerson Televison & Video
My led emerson 32 inch flat screen will not power on manually even! red light comes onand flashes 5 times then the red light just stays a solid red and the tv never powers on......nothing! tried 2 ways of...
It has gone into safe mode as an internal fault has been detected you need to take the back off to repair or replace board's up to and including the screen
Aug 15, 2017 | Emerson Televison & Video
I Have A Emerson Lf320em4A Replaced The inverter Board With A New One. No Now Display?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 09, 2017 | Emerson Televison & Video
I have a Emerson LED 32 LF320EM4A has sound no picture
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 01, 2016 | Emerson 32-inch 720p LED TV Refurbished
I have a 32in emerson tv and right now the screen is black but the sound is still on. What could be the problem?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
May 06, 2016 | Emerson Televison & Video
Emerson LC320EM2 HDTV
If the inverter that supplies power to LED back-lights, the screen will be dark, and sound will be OK. Check it. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Apr 26, 2013 | Emerson 32in Class LED-LCD 720p 60Hz LED...
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
My Emerson LC320EMX tv wont power on. Can you please tell me if there is a way to fix this?
Check ur power out source?If tv have no power LED light indication on the tv bazel frame at all.Tv power LED light indication on the tv bazel are flashing.Tries tv unplug,replug it back like about an hour later for tv to do a resetting itself back to the factory setting.Tv should be working again.If still have the same result.The tv power supply board is the causes and the problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Timer LED flashing and tv screen not viewing
does the tv have a separate tuner box? if so check the cables i have a pioneer that does that when the connection isnt in sync
Apr 09, 2008 | Televison & Video
Televison & Video Logo
353 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
