Question about Bosch Classixx WFL 2066 Front Load Washer
The outlet hose on my classixx 1000 seems to have a blockage
I think the outlet hose is partially blocked.the machine smells awful when it is draining and sometimes the washing is covered in smelly s..t when it has finished.I have had a look around the back of the machine and removed the lid but cannot figure out how to get the hose off...that is assuming i need to.
    Sergeant:
  • 228 Answers
FILL DRUM WITH HOT WATER FROM A JUG SHUT DOOR AND PUT ON SPIN REMOVE HOSE FROM OUTLET AND PUT IN BUCKET OR SINK ACTIVATE SPIN AND SHAKE AND STRETCH THE HOSE VIGOUROUSLY THIS WILL SHIFT DEPOSITS KEEP DOING IT TILL WATER RUNS CLEAR MAKE TAKE A WHILE.
Posted on Sep 19, 2009
Drain outlet maybe blocked drains too slowly
need to check ur drain hoses and the water pump for blockage or obstructions
Jun 19, 2015 | Washing Machines
Why does machine not always spin dry?
One of the most common causes of machines not spinning is because the water has not been fully drained (pumped out)
Check that the pump is not blocked as well as the hose not blocked or kinked. There may be detritus in the button trap which is partially blocking and slowing the drain flow.
If you put the machine on 'Drain and Spin' for a second time it may spin. This would indicate that the pump is not emptying the machine quickly enough on the first attempt due to a partial blockage.
Good luck
Nomess
Jan 25, 2015 | Washing Machines
What dose e5 mean on my dishwasher
Hello tom.... e5 is a drain error - machine is not draining - check drain hoses. If your trap under the sink is blocked, or even if your garbage disposal is blocked, interfering with the proper draining of the machine, you will get this error.
Another cause is often a blockage or a partial blockage somewhere between the machine's drain pump and the sink trap. To check this remove the lower front panel on the machine [usually just 4 phillips head screws need to be removed], and then disassembe the drain hose from the pump in the lower front of the machine. Also unscrew the pump from the frame and physically check it for debris, sometimes even a chunk of glass or bone.
Once you locate and remove the blockage, and reassemble everything, the machine should work once again. Joe
Thanks for choosing Fixya!
Feb 01, 2011 | Dishwashers
MACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
May 31, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My classixx has stopped spinning and draining water.I have already checked the pump.Its clear.
If it is not draining the water, then either the pump is faulty, or there is a blockage in the outlet hose from the pump, or possibly a blockage in the hose from the drum to the pump.
Mar 24, 2010 | Bosch Classixx WVF 240S Front Load Washer...
NOT SPINNING OUT DRY ENOUGH
There is a partial blockage in the drain line. You need to remove the pump and check for obstruction at the impellers. If clear, check the pipes from the drain motor back to the drum and to the pipe outlet for partial blocking.
Oct 23, 2009 | Hoover HTC243 Top Load Washer
Bad smell coming from washing machine
It probably is related to your drain outlet, depending on the set-up, I would suggest you remove drain hose and clean the place where the drain hose enters the drain system, if possible, clean all associated pipework
Please rate my solution.
Thanks.
Sep 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Smelly clothes
two things
are you using liquid detergent? if so, change to powder
is there a water barrier in the drain? if not, you are getting the smell from your drains
Sep 30, 2008 | Washing Machines
Bosch Classixx 1000: Won't drain
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
May 26, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
229 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
