Question about LG LHD65EBL Dehumidifier
My LG LHD 659EBL has a very loud vibration
My LG LHD 659EBL bought 2 months ago has had a very loud vibration which has gotten worse. Vibration seems to be coming from many parts of the cabinet.
Loud vibration
vibrations are from unbalanced item
check for dirt build up on the fan blades
Jul 24, 2015 | Dehumidifiers
It is loud vibrating when comp. runs if I tip the unit up 3or4 inches it stops vibating is this ok too run this way?
No, not really. As the unit has to be in a level position to operate properly and not overflow.
If the unit is sitting on carpet, this will often times cause the vibration noise. I don't know why, but it does and it does with my 4 year old LG unit. I have noticed, that once the tank reaches the 1/2 full point, it will vibrate sometimes. I solved the problem by firmly smacking the left & right sides of cabinet at the same time, with my open hands. The vibration stops immediately and continues to run until it shuts off because, the humidity extraction level has been reached or the tank is Full & needs to be emptied.
It's a simple solution, but it works. I hope it works for you and thanks for choosing FixYa.
Aug 23, 2011 | LG LHD459EL Dehumidifier
I bought an LG dehumidifier last summer and it worked fine until about 2 months ago. Then there was this constant clicking noice. It seemed like it was electrical with the switch or something. It was...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 22, 2011 | LG LHD45EL Dehumidifier
Very loud vibration when the fan runs.
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Good luck.
May 15, 2010 | Goldstar DH504EL Dehumidifier
Bought LHD 45ELY6 at garage sale with no manual.
Try Googling (LG)(LHD45EL)(manual) without parens.
May 26, 2017 | LG LHD45EL Dehumidifier
The unit vibrates and has a pulsing sound. I have
These things tend to make a bit of noise, some more than others. You will not be able to do much about the internal produced noise but you can do a lot with the resulting vibration noise.
While the unit is running, take a few minutes and actually touch the unit ALL OVER, you are listing for any vibration noise to cease or be less so where you are touching. This includes the collection pan and the filter. Slightly Tilt the unit in all directions. Make sure that the door to the collection pan is closed properly. Take a few strips of the peel-off adhesive sided thin window/door insulation and apply to the bottom of the collector pan, if it sits ON the bottom of the unit. Place an inch or two thick blocks of foam rubber under each corner of the unit. Make sure the unit is level. Some where along here you will stifle some of, or maybe even most of the noise.
Good luck. :)
May 06, 2009 | Dehumidifiers
Loud Vibration
Check the front water bucket handle.
Sep 10, 2008 | Haier Dehumidifiers
No water collection
Check if the fan is running by putting your against the grill in front or back of the unit.
Jun 23, 2008 | LG LD65EL Dehumidifier
Noise vibrations in dehumidifer
sounds like a sealed system issue it has a 5 yr. warrenty on the sealed system, cost to repair might mean an new one instead
May 03, 2008 | Dehumidifiers
LG LHD65EBL Dehumidifier Logo
148 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
