Question about Compaq Presario 5000 PC Desktop
Finding a short in PC components.
This computer wouldn't turn on. I thought it may be the power supply, so I used another one and yes, it was the power supply. However, when I tried the new PSU, I had all other peripherals disconnected except for the motherboard and video card. After the mother board loaded up fine, I thought that the problem was solved. So, I went ahead and put everything back together, but when I went to turn the thing on, it did just like before!
I checked voltage at all the connectors and both PSUs are definitely broken now. So, I've concluded that there must be a short in one of the components that I had disconnected. They are:
Modem, ethernet card, floppy drive. 2 HDD, and a DVD-RW.
I'm guessing that its one of the drives that require power, but I guess it could be one of the PCI cards too. I thought I could check the power connectors of the drives to see if they were shorted, but I don't know what Ohm reading to expect. So, I won't know if the reading is normal or not. I don't want to keep burning up PSUs just to find the short.
Does anyone know the normal resistance readings for floppy, hard disk, & optical drives on the power terminals?
  • 2 more comments
  • InSub Beckley
    InSub Beckley Nov 18, 2007
    I'm sorry, check what out? Do you have a link or something?
  • InSub Beckley
    OK, for a second I thought you were talking about your avatar. :)
  • InSub Beckley
    Thanks for the chart, though it is too small for me to read. I think I found that same chart somewhere on the web, but it didn't have any specific meter readings, as far as I remember. Do you have a website or link I can find the info at?
  • InSub Beckley
    Oh yeah, I think it may be the DVD-RW drive. I got a reading of 0 Ohms between pin 1 and 2. That may be the short. I've got to check some other things, and I want to be sure I've eliminated the short before installing a new PSU. The last one I just happened to have laying around. The next one's gonna cost me.
  • 56 Answers
Check this out.
Posted on Nov 18, 2007
  • 1 more comment
  • Tony Clayton
    Tony Clayton Nov 18, 2007
    The chart I have can't be uploaded to the page.
    I am going to try soething different to see if it will let me up load.
  • Tony Clayton
    Here is a chart that will help you
  • Tony Clayton
    just plug in one at a time you might have a wire pinch some where so check your wireing.
I stopped using my acer aspire l100 when I got a laptop. I wanted to use it again so the other day I hooked it up and I got nothing. There is no light on the computer and the power will not switch on. My...
First things first if you put the wrong RAM in it would still turn on but it would beep at you. If the front switch isn't sticking I doubt it is that. You can test it by following the wires from the switch to the motherboard, disconnect the wires and use a flat screw driver to make contact between the two pins or if more pins make contact between the + and -, if it turns on then yeah it's the switch. The small 3v battery is only used to save your BIOS settings.
Lastly, yes it most likely is the power supply. I'd really just start with the power supply as it is the most common component to go out.
Comment back if you need more assistance.
Aug 25, 2011 | Acer Aspire L100 PC Desktop
The computer keep shutting down.... i had taken down and he feel the mother board or something had been shorten circut.. i had it for 3 years... other than that seem that everything is fine but shut down...
If there was a short circuit it wouldn't power on period. If it shuts down completely and not rebooting your most likely teleconferencing one of the following
  • Power supply is crapping out (less likely)
  • Your computer is overheating (Most likely)
If it is rebooting then your most likely experiencing a software crash perhaps due to a failing hardrive or just general operating system corruption.
If your computer stays up for more than a few minutes try downloading speedfan (click the words "Speedfan 4.4" not the giant button (thats an ad) http://www.almico.com/sfdownload.php Run it and it will display your core and CPU temps anything over 60-65 is pretty **** high, shutdowns will usually occur higher than 75 C though. If you know how to enter BIOS (usually F10) while the system is first booting up, some BIOS will allow you to set a shutoff threshold.
After thought... failing CPU fans can also cause a computer to shutdown.
Comment back with your finding or if you need further help.
Aug 12, 2011 | Computers & Internet
My computer will not turn on.i thought my battery was bad, but when i take it out and try to use adapter, computer still will not turn on. power light turns on for 5 seconds then back off, monitor does...
Your computer in my experience is in short circuit protection mode.
Leave it off as further use can cause extensive damage. Get your laptop computer to a computer technician as faulty components need to be diagnosed and replaced.
Claim warranty support if you can!
All the Best!
damnor01
Feb 02, 2011 | Dell Inspiron E1405 Notebook
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My HP G6000 Notebook PC, wont turn on. the AC charger adapter lite powers on when connected but wont turn on the pc. three days later my computer still wont turn on, but now the bottom three lite...
It is a probably a short in your hard drive or power supply to the hard drive. Honestly may be cheaper to replace the computer if it is a power supply short, laptop internal components are expensive to repair.
Sep 21, 2010 | HP Computers & Internet
Computer will not turn on....how do I check to see if power supply is faulty? I have power supply removed and have a tester to check for dc voltage etc
I just went through a heap of troubleshooting with power supply issues before swapping psu's and finding this was the solution to my problem. Had a closer look at my psu that was faulty, the green light was flashing on the psu, unplugged all components and thought that I now had a non-flashing green light on my psu, on closer inspection the light was actually flashing very fast so appeared to be an almost solid light...the psu was stuffed so replaced it and no more issues. If your power supply has a green light check to see if it is flashing when plugged into voltage with nothing connected to it. If it is a solid light then it is probably ok.
Jun 16, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Replacing the power supply on my acer pc. Liteon model No: ps 5221-06/ where to find it?
Yes,
https://www.pacificgeek.com/product.asp?ID=846862&C=304&S=-1
It's made by Delta for Acer. Model Number is
DPS-220UB A
I know you didn't ask for this information, but I feel compelled to tell you.
I know it's hard finding the right style/shape of power supply to fit in your computer case,.
BUT,
the above power supply is a cheap quality power supply. Anything in power supplies made by Delta is.
(Plus it seems to be the only thing available)
I wish you would consider buying a decent, economical, ATX computer case, and put the hardware components out of your Acer into it.
The reasoning is,
1) There will be more airflow. Airflow, is used to keep the hardware components inside the computer cool.
This increases the lifespan of the hardware components.
2) An ATX style of power supply can be used. The style that approximately 90 percent of personal computers, out there use.
You could buy a power supply for the same amount of money, that would be more Reliable, have more Power, run Quieter due to a larger fan, and has higher quality components inside.
3) Should you wish to add additional harddrives, and optical drives in the future, there will be room.
Feb 16, 2010 | Computers & Internet
Dont power on all the time
Ok, if it shuts off itself after a short period of running it's a hardware failure. Most of the times (if that is the scenario) it is caused by a faulty power supply unit or a plugged CPU fan heatsink (yes, the little aluminumor copper-made block sitting on top of the cpu). Open up the side of your computer's tower and inspect the inside (make sure the power cord is disconnected first). Check for major chuncks of dust or lint. If so, get a couple of dust off cans and spray the whole content inside paying more attentions around the motherboard (It would be better and more efficient if you use an air compressor but watch out for the psi because to much may break some plastic components). After you do this, put the cover back in the computer and reconnect all the wire connections, including power, turn it on and try it. If the problem persist, then you may have a bad Power Supply Unit (PSU) that just heats up and cannot convert the power needed for computer components to run continously. You can get a PSU tester at Radio Shack for a few bucks. Good luck.
Jan 05, 2010 | Gateway 507GR PC Desktop
Won't boot
power supply isnt putting out enuf power
Apr 25, 2009 | Intel Motherboard
NO Power up at all, Nothing!
Do you have a LAN connection on the machine that you use? That would be an area to start to make sure that (when a LAN cable is plugged in, the incoming and outgoing lights will blink) the power supply still works. If the power supply does still work, it could be the motherboard or CPU which isn't working. It could be something simple like thermal compound needs to be reaplied to the CPU, or there may be faulty hardware. Let me know if the power supply is still working.
Oct 11, 2006 | ASUS A7N8X-E Deluxe Motherboard
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
