Question about Lexmark X4500 MFP Flatbed Scanner
OPTIONS CAN I USE THE SCANNER AS A STAND ALONE TRUE THE USB CABLES , AND IF YES WHERE CAN I GET A DRIVER AND UTILITY DISC Y BOUGTH MINE AT SECOND HAND
  • 3 Answers
Unfortunately this unit will not even completely start up without the appropriate Lexmark printer.
Posted on Sep 21, 2009
I need help to reset password Client - N380 from thinstation
This is the spec for the device
Model
Thin client NP-N380
Stand-alone operating system
WIN CE 6.0 OS
Maximum Users
Unlimited
CPU
ARM11 800HZ
RAM
128MB
STORAGE
128MB
Audio output
yes
Audio input
Yes (except remote desktop connection)
USB Port
3 or 4
COM TAP
Derivable
Support scanning gun
YES
Support touch screen
YES
Support printer
YES (Network printer)
Power input
5V~2A power 5W
Communication distance
Network Cable biggest communication valid distance
Size(mm)
115*115*26
Support Max resolution
1280*1024or1440*900@24 color depth
Whether to support the latest system patch
support
WIFI
Optional(150Mbps)
Support of the operating system
win xp/2000/2003/7/vista/2008
Keyboard mouse port
USB
Whether can do secondery development
YES
Whether could do USB upgrade
YES
Get the password from this documentation.
http://www.thinclientech.com/wp-content/uploads/2014/01/N380-Manual-Instruction-Embedded-Technology.pdf
Sep 26, 2014 | Computers & Internet
Hello Steffen, We have a 8830 scanner Synergix.
Hey Panos,
What are you trying to feed a paper roll or single sheets or are you telling me you cant feed the original to be scanned? Can you copy or print internal status pages from your Xerox?
But it sounds like thats not the problem as it isnt hooked up and your lappy as it dont have a serial port you only have USB...... but this is a network printer.... do you have a network or it is just a stand alone lappy?
So I guess.. stand alone lappy to Xerox.... you will need to network it... and if it just a stand alone lappy ie no network then you will need a non standard network cable called a crossover cable to go from scanner to lappy but you will also need to set up a network with them manually asigning IP's of each to be on the same network, then hooking with a crossover (normally red never blue) network cable, and you will also need the software installed on this lappy no matter which way we go
Spose you could try a serial to usb adaptor but they will have issues propally when trying to use that sort of interface on scanning, normally one has the print server that is an option on your scanner to interface with the likes of a laapy, so I dont think it would workor a good idea to go with an adaptor
Well come back with some more info because the more info you can give me about your problem the better i can understand it.. cheers
We are talking about one of these beastys.. User Manual
Cheers
Steve
Dec 16, 2011 | Xerox 8830 Copier
Cannot get WinXP to recognize LS9208 scanner via RS232 or USB. Motorola utility 123Scan states that the "connected scanner uses a plug-in that is currently not installed." Have tried all OPOS...
Its not a driver problem.
-Go to Control Panel.
-Click Accesibility options
-Select General tab
-Check Use SerialKeys
-Click configuration Button
-Select the Com port
-Select 9600 baudios
-Click accept Button
Thats all.
A mi me funciono con esos pasos. Suerte.
atte
oshamo
Jan 19, 2011 | Symbol LS9208 Hands Free
Xerox 4800 one touch flatbed scanner
Uninstall drivers and remove usb cable.
re-install drivers without usb attached.
Reboot and attach usb cable
Sep 17, 2009 | Xerox One Touch 4800TA Flatbed Scanner
Scanner on my "All in One HP 6110" refuses to work any longer
Please get back to me with the following information to assist you further.
  1. How is your printer connected to computer? (USB or Network)
  2. Have you installed Full feature software?
  3. If you are connected with USB cable make sure the cable is connected directly to the printer without any USB hubs.
  4. What is the OS?
  5. Are you able to copy a document on the printer (stand alone copy)?
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Photosmart 145 fix
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | HP PhotoSmart 145 InkJet Printer
Xerox 510 color scan option not turned on
HELLO
CALL XEROX ON THE FREE LINE FOR PURCHASING THIS OPTION ON
THIS WILL COST YOU RS:49,000 + VAT
THANKING YOU
RAMANA
Dec 29, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
I bougth a router for my comp. it is a window vista seems to be fine when i loaded it. then i bougth a usb adapter with speed booster-g. now do i put this one in my sons comp. and what is the cable that...
If it's a USB adapter, the cable is just a USB extension cable, so that you can move the adapter around for best signal strength without having to move the whole computer.
Remove the phone line, because he no longer needs it to connect to the internet.
Just let Windows load the drivers it needs for the adapter (use the CD that came with it if the computer asks for it).
Sep 10, 2008 | Computers & Internet
Nec flatbed 650u scanner
If it's a USB cable, you can get that at pretty much any store.. such as Walgreens or CVS, Target, K-Mart. Good luck!
Aug 06, 2008 | NEC MultiReader PetiScan Flatbed Scanner
MOTOROLA RAZR V3M MP3 DRIVER/UTILITY DOWNLOAD
HI,
I BOUGTH A DATA CABLE FOR MOTOROLA RAZR V3M OVER EBAY BUT THE DRIVER/UTILITY CD WAS NOT INCLUDED, NOW I'M TRYING TO DOWNLOAD SOME STUFF INTO MY RAZR AND PC WILL NOT RECOGNIZE IT. WHERE CAN I FIND THE DRIVER TO DOWNLOAD OVER THE WEB?
XP box won't see the phone when connected via the USB cable. The phone charges when connected. Have swapped several times the USB port to see if connectivity was good. It was.
May 06, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Lexmark X4500 MFP Flatbed Scanner Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
