Question about Eureka 4700A Maxima Bagless Upright Vacuum
Eureka 4700a bagless vacuum
Will not pick up, no spin in canister. no obstructions in hose or at bottom port. hepa filter is clean. brush does spin on release. what do you think?
  • 1 more comment
  • Fierywon2 Nov 26, 2007
    no suction when used normally although when i disconnect the she from the base there IS suction direction from the hose. I have checked for any blockage and cleaned out the filter/compartment of any dirt. The belt IS working, the brush IS spinning. I don't know what else to do
  • Anonymous Feb 20, 2008
    I have the same problem.. When disconnecting the hose from the head, it picks up fine, but pushing along picks up nothing.. Everything seems to be spinning. Could there be a belt problem.? I have no manuel so I don't even know where the belts are. Any solutions??
  • swingengin Jan 12, 2009
    I have the same problem. Also, it smells really bad when its running.
  • 20 Answers
It's probably the lower tube that is plugged, disconnect the lower tube at the elbow, use a large pipe cleaner (bent at the end your pushing through, as to not puncture the tube itself.) it should emerge just behind the brush. check in and around the pipe cleaner for any debris.
Posted on Jan 06, 2009
    Problem Solver:
  • 7 Answers
I'd check the hoses again and see if there are rips or leaks. If it has a seperate motor for the suction, I'd make sure that it works.
Posted on Nov 21, 2007
Tip
Bissell Bagless Upright Vacuum not working
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Mar 21, 2010 | Vacuums
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
No suction
there is a clog somewhere :) take the canister off and check the opening and the hose. sometimes items get caught in the top of the canister.. this greatly reduces the whirlwind effect..
Mar 28, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
High pitch whirr
when you remove the canister to empty it there is a filter on the bottom that can be removed and cleaned or replaced check to see if there is also one on the top.
Apr 14, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Loss of suction and bag full
Sounds like you still have a clog, either in the hose, drop something down it to see if it comes out the other side. The other place is the dirt inlet by the brush roll. Take off either the top cover or the bottom plate and you can check it out.
Feb 19, 2008 | Vacuums
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka 4700A Maxima Bagless Upright Vacuum Logo
295 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
