Question about Bosch Classixx WFL 2066 Front Load Washer
How does the outlet hose come off as it is blocked? it doesnt look very straightforward to me.
    Sergeant:
  • 228 Answers
YOU SHOULDNT NEED TO REMOVE HOSE TO CLEAR IT FILL THE DRUM WITH HOT WATER A FEW JUGS FULL SHOULD DO PUT ON SPIN AS IT WILL TRY TO DRAIN FOR LONGER PUT THE HOSE IN THE SINK OR A BUCKET AND SHAKE IT VIGOUROUSLY AFTER A WHILE A VERY SMELLY SLUDGE WILL COME OUT DO THIS TILL WATER RUNS CLEAR.
Posted on Sep 10, 2009
How to fix the washer "f" notification?
If doesnt drain the water first, then the pump outlet filter is blocked
Dec 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Zanussi zwf1437w
Possibly blocked sump hose( bottom of drum) or pump not running,,,,drain water by putting outlet hose down too ground level, when water drained out put machine on spin. If machine spins ok, then you have a pump problem,,,,if water won't drain out when outlet hose at ground level then you have a blocked hose
May 25, 2013 | Washing Machines
Where is the thermostat located in the 06 stratus
  • Find the location where the upper radiator hose connects to the intake manifold of the engine by tracing it from the radiator to thermostat intake housing bolted to the intake.
  • 2 Remove the radiator hose from the thermostat intake housing by loosening the band clamp that secures it into place. With the clamp loosened, pull the hose off the housing.
  • 3 Remove the two bolts that secure the housing to the intake manifold and then lift the housing off the intake.
  • 4 Lift the thermostat out of the intake manifold and place the new thermostat into the hole. The end of the thermostat with the pin protruding from it sticks out of the intake manifold.
  • 5 Lift the thermostat intake housing gasket off the intake manifold and place the new one onto the intake manifold.
  • 6 Place the thermostat intake housing onto the intake manifold and bolt it into place. Reconnect the hose using the band clamp.
  • Six-Cylinder Engines
  • 1 Drive the Dodge onto a set of front-end ramps and secure the parking break. Allow adequate time for the radiator fluid to cool down. Thirty minutes is usually adequate.
  • 2 Loosen the petcock on the lower right hand side of the radiator and drain all of the radiator fluid into a drain pan. Close the petcock once drained.
  • 3 Trace the lower radiator hose to the location where the hose connects to the engine block. The metal housing the hose connects to is the lower thermostat outlet. Remove the hose from the outlet by loosening the band clamp and then by pulling the hose off the outlet. Be careful--some fluid will drain from the hose.
  • 4 Remove the two bolts that secure the thermostat outlet to the engine block and pull the thermostat outlet off the block.
  • 5 Discard the O-ring inside the bottom edge of the thermostat outlet and place a new one into the outlet.
  • 6 Pull the thermostat out of the engine block and replace it with a new one. The end with the pin protruding from it sticks out of the engine block.
  • 7 Place the thermostat outlet onto the engine block and secure it into place. Reattach the lower radiator hose with the band clamp.
  • 8 Open the radiator filler cap located on top of the radiator and fill the radiator with the fluid previously drained from the system.
  • please dont forget to give good rateing thank you
    Dec 28, 2010 | 2006 Dodge Stratus
    Truck is running hot. Relaced thermasta and still runs the same. Noticed the top hose gets real hot while the bottom one doesnt. Dont get it.
    The cooling water doesn't seem to making it through the radiator. Look for plugged radiator, blocked upper or lower hose, or ineffective water pump. Remove the inlet and outlet hose after draining coolant from the radiator. Hold your hand over the lower hose outlet while someone fills the radiator with cold water. When full, leave the cap off, then remove your hand from the outlet. If the core is unobstructed, the water will rush through it in a few seconds. Check the upper hose inlet--there should be no obstruction. Inspect the interior of each hose looking for collapse or other blockage. If ok, that leaves the water pump--remove it from the engine and check that the impeller turns solidly with the driving pulley. Any looseness there is grounds for replacement. Hope some of this helps!
    Jun 29, 2010 | 2004 Dodge Ram 1500
    Doesnt pump water out
    The fault could be either the pump out motor in line with the outlet hose (test by disconnecting the 2 push on terminals and connecting supply voltage directly to the 2 terminals. If the motor spinns the motor is OK and fault lies with electronic switching circuit - not normaly a DIY repair if the motor does NOT spin it indicates the motor is open circuit and needs replacing - quite easy job). Assuming you have checked the obvious - outlet pipe not blocked/obstructed.
    Mar 22, 2010 | Dishwashers
    I have a 92 sedan deville, the problem i am having is very low heat.The heat is warmer at idle but cooler when driving. I have replaced the water pump, thermostat and flushed engine out.
    remove the heater hoses from the connection on the bulkhead and flush the heater rad out ,if it still doesnt work then block the bottom outlet off with a cork and then using a funnel and piece of hose connected to top outlet use a 20% caustic soda solution to fill it with and leave half hour then flush it out again.fancy wasting money on pumps and whatever else ,why didnt you ask me first
    Jan 18, 2010 | 1992 Cadillac Seville
    Washing machine drain hose too short
    add extension with hose clamps will be fine
    May 26, 2009 | Washing Machines
    Leaking Candy Aquaviva 130
    Its called 'The Main Outlet Hose' But you can probably make a fairly good repair by wrapping Gaffa Tape around the hose. Tip! after replacing / repairing the hose tape some padding around it, so it doesnt wear again
    Oct 30, 2007 | Candy AQW130 Front Load Washer / Dryer
    Hoover wdm120
    more than likely that yor pump hasnt let all the water out try getting your outlet hose from under the sink and place into a bucket low to the ground if water comes out than your door will open after a short while if water does come out than make sure your pump or drain hose is not slightly blocked if not then your pump is on its way out also if water doesnt come out of drain hose than take it off at the pump if it comes out then,then your hose is blocked m8
    Aug 20, 2007 | Hoover H120M Front Load Washer / Dryer
    Washer machine Won't drain
    more than likely that it is blocked pull the washer clear so you can see the back get your outlet hose and place into a bucket and see if the water comes out if it doesnt than pump/pipe blocked better off taking washer outside because when you release the outlet pipe from your pump thert will be alot of water that will come out if it comes out of the pump than your pipe will be blocked m8
    Aug 14, 2007 | Tecnik TKL9260 Front Load Washer
    Bosch Classixx WFL 2066 Front Load Washer Logo
    76 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
