Question about Philips Magnavox 15MF400T 15 in. LCD Television
I have no audio.
I recently move to a new place. I transported my tv with care. It sat on the passenger seat. After I plugged it in and connect the cable wire, it turns on but now I have "no audio".
I've tried everything that's on the menu ... no results. I did notice a "factory reset" selection. When I select, it only say "yes" and an arrow directed to the right. I don't know what to do next. How do I reset to factory settings? Would this fix the problem? Is it something different that could be fixed without resetting?
Any solutions? Please help. Thank you.
  • jmalamo Jul 16, 2009
    I have a Magnovox MF 605T/17. I just moved to a new place and my HD's volume is not working. It was never banged in the move. What could have happened?
    Please advise.
    Thank you.
    Mike
    President:
  • 2,777 Answers
Hello there, sorry to hear about your problem,
Most likely it can be solved by doing the rest, but lets check a few things first. Do you have your cable plugged directly into the COAX on the back of the TV? That is the single line (usually black) cable, if you are not familiar try a google search for COAX and check out the pictures.
If so, do you have any other devices attached to the TV such as a DVD player or anything like that? If you do, does the problem persist on those as well? And when you adjust volume on the TV to you see some kind of indicator moving up / down to show that it should be adjusting the volume?
Let me know and we can get this fixed.
Thanks
Tim
Posted on Jul 16, 2009
  • Philips Master
  • 19,396 Answers
Unless you are using external speaker or a surround system, the only functions that can cause no sound coming from TV speakers are Mute and the Volume controls.
If the TV is not in Mute, then there is a problem that is not related to settings.
The TV is reset simply by leaving it unplugged five or ten minutes.
Try also plugging and unplugging a jack in the headphones plug, and test the system with headphones.
If that did not fix the problem, try connecting a DVD with a different cable. If DVD has sound , then the problem is connection cable to receiver, or the connectors that on LCD tvs are often integrated with the mainboard.
That can be resoldered or fixed replacing the board.
If that is the case call the service number listed on the user manual.
Regards.
2008 Kia Amanti power seat is not working on the drivers side, passenger side works
You will need either a new/salvaged motor or switch for your seat. One way to troubleshoot is to apply a 12-volt current to the seat motor's power connections and see if the motor moves. If the motor moves (even sluggishly), then the most likely culprit is the switch.
Oct 27, 2014 | Kia Amanti Cars & Trucks
Remove honda accord rear and passenger seats
Since you did not list the year of your honda then I will just say off the top of my head to use air tools then unbolt the nuts and bolts hold the plate that your seat is able to slide back and forth on. next back seat is easy to unbolt and if you just look then you will see places you need to unbolt to remove.
Nov 12, 2013 | Cars & Trucks
KP61S75 has 45* angled stripes.
1? you must test the power supply, the absence of this cause a LOT of problem, test a= fuse, filter, c.breaker rectifier.
2) test the tuner, i-f, video detector, AGC, section
3) if the tv has external POT adjustment for vertical, horizon, do it carefully.
4) tight any wires connector loose, or bad contacts.
God bless you
see the diagram
Jul 18, 2012 | Sony KP-61S75 TV
We recently moved and tried to hook our tv back up and now there is no sound.
check out the connections if you are using external source of audio/video input, check carefully if you had plugged it wrong, secondly check the speaker connections. cross check with an external seperate input. Further we need to look into the cicuit, into the audio amplifier, power or failure of the audio process. Internal failure detection will require some signal injection and tracing to the fault. good luck
Jul 01, 2010 | Televison & Video
Vw transporter 05 central locking not working cant open side or passenger doors at all can only open drivers door and boot manually with key
water ingress in wiring loom below drivers seat, mainly loss of power to pin 23 middle multi plug blue and red wire middle multi plug.
remove drivers seat/frame trace wire back to corroded connection and repair. you may also have to remove passenger seat depending on where the break is. dealer quotes upto 2 hrs
Jan 17, 2010 | 2001 Volkswagen Jetta TDI
The front passenger seat is jammeed. Whenever I push the button to move the seat back and forth, it only goes a short way and stops. Currently the seat is jammed forward and I cannot get it to slide back...
Check to be sure something isn't jammed under the seat to prevent it from moving past the point. Also check your electrical connections to be sure they are plugged in tight. Your seat may move to a point and unplug (but remain plugged in). Next there are control circuit boards under the seats that can go bad and cause intermittent problems.
I had to replace one recently on a 2002 Envoy.
Dec 05, 2009 | 1996 Ford Explorer
NO POWER
I know this might sound strange, but there are 2 power buttons on some Yamaha recievers. Power and Standby buttons. The power button is very small and located 7 o"clock in comparison to the much bigger stand by button. Once you turn your power button on then try hitting the main power up off the remote & see if that does it.
Turk_97
Oct 08, 2009 | Audio Players & Recorders
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Hitachi 53sbx10b
Try the auto convergence feature of the TV. Press the button on the front of the tv and wait about 5 minutes....
Apr 27, 2007 | Hitachi 53SBX01B 53" Rear Projection...
TV/SAT Video channel went out - Pioneer VSX516
Double check the video connection cable directly out of the SAT reciver and the video cable out from the Pioneer reciver, as there maybe an intermittant connection in them. If you replace them or sub them for known good ones, and you still have this probem, there is a switching IC inside the pioneer that has to be replaced.
Jan 04, 2007 | Pioneer VSX-516-K
Philips Magnavox 15MF400T 15 in. LCD Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
