Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 Turns off after a short while
Hi, I've never had problems with this tv but all of a sudden the uunit shuts off afer a short while of usage (about 20 min).
i know its not the electricity in my house, there's no sleep timer on.
i 've been told to replace the power board ($109) should i replace anything else while I'm at it? Is there a chance the new part will be ruined by another faulty part?
Need some advice, Thanks
  • Anonymous Nov 18, 2007
    the tv has totally burnt the board it started with shutting off know it started to smell and kick off and on by itself
  • vault4455 Nov 18, 2007
    Yeah power board #264114R
    Genius:
  • 1,694 Answers
1)Solder any / all bad connects on main/power board +
2) Pull little sister board loosely mounted on one connector =
solder connector pins = re-assemble..............T.
Posted on Nov 18, 2007
  • Vista Electronics Nov 18, 2007
    PS do you have power board part # ????........................T.
TvRCA d52w20 52 pulgadas doble imagen
mi tv rca no enciende solo dejo de funcionar y ya, que es lo que debo de revisar en este caso?
Jul 21, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W20 turn on with a blue screen and then turns off within 3 sec's. It goes off like someone has switched off the TV. The light blinks and goes off. Can anyone help
Your blue tube has a short. What you are seeing is the TV turning on and the blue tube going to full brightness. It then draws enough current that the television's protect circuits shut it down.
Need the full model number which should include a BYX or just YX followed by a number. Going off the D52W20BYX1 the blue tube would be part number 263049 which https://www.encompassparts.com still has a few for $220 before shipping.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns off and comes on
have u been using the buttons on the front?
if so it could be the button is stuck on the tv..
or possible a short in ur remote..
Jan 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
when it shuts down and you try to turn it on again does the led blink/ If so how many times does it blink? let me know and I will try to help you out with the problem. Also let me know does the picture do anything abnormal just before it shuts down?
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY RCA TVE WONT TURN ON
Did you change your battery from the remote?
Dec 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turns on and off
Best to call a service center to check it.
Sep 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
